Topics49,899
Posts838,030
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Have you found any pads which don't squeal at low speed Nick? I have the same issue and it drives me nuts. Only way to stop it is to stand it on its nose which does cause a lot of squealing noises behind me instead. Hi Kevin, as per James' reply I haven't personally found any yet. I am still looking at options. Gents, an update, the squealing of my new pads (mintex 1144) has reduced to almost nothing, I' suspect that the squealing is due to pad contact with clean discs (when new pads are installed the discs should be cleaned of all old pad material), material from the new pads is then transferred to the discs during use, this appears to reduce the squealing, which was really only occurring When braking from very low speeds. Good to know Gareth, Mintex are very highly rated.. if only they did S1 pads!
Aero 8 GTN #11
Posts: 1,415 |
I've got S1 Mintex Pads on the shelf in standard and M1144 materials... Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
I've got S1 Mintex Pads on the shelf in standard and M1144 materials... Simon @ SiFab.co.uk Hi Simon, Do you have front and rear? Also I don't know a huge amount about Mintex (other than they are really good) but what compounds do you have/do they do? Happy to chat via PM if easier. Regards, Nick
Aero 8 GTN #11
