4 members (Player99, Luddite, DaveW, mph), 168 guests, and 41 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,142
#53832 06/12/10 09:18 AM
Hook Offline OP
Hi,
Need a little advice please.The factory had my seat out for a small repair and now I can't get it to slide fore and aft without a monumental effort. I assume something's got tightened up too much but want to make sure I attack the right bits.
Thanks in advance!
Dave
Is it lubricated on the runners?
Hi 'Hook'
I, unfortunately, don't have any answers for you on this one. Only to say that I have a one year old 4/4 and the seat adjustment on mine are really quite tight (both seats).
I would assume that the runners on my seats would be lubricated from new so if they can be adjusted to run a bit easier, I too would be very interested to hear from anyone with a solution.
Cheers,
David
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
The runners are quite sticky anyway, but by the sound of it, they have been replaced slightly out of line. If you look at my 'How to' remove the seats post, you'll see that mine were retained by six bolts - three each side. Morgan being Morgan, yours may be a bit different, and you may or may not have wooden spacers under the runners. When my seats were out I applied some spray grease to the runners, and this did help. I suggest that you slacken off the bolts on one runner, and see if there's any jiggle room. If not, loosen both and jiggle. No need to remove completely unless you want to do a thorough lubrication job - probably not necessary.
Hook Offline OP
Dave, Thanks I'll try that. Not sure how to find your post on removing seats. Not too good with this website sorry.
Cheers
Dave
Hook Offline OP
Cheers Dave, will get to work on this soon.
Dave
