Morgan Aero 8
7 members (Image, andymog1, DJC, John V6, Simon, TalkMorgan, IcePack), 252 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,119
Page 3 of 3 1 2 3
Smile, it confuses them
When the Coupe was delivered to us it was 2013 + 9 months of Morgans PR use. A fair list of fettle opportunities arose in short time.
Drunken fuel level gauge
Terrible filling rate with blow back
After a couple of goes they did manage to change the pipe to the tank, angle of the opening and wiggle. It would appear to be possible.
I think I remember a thread talking about the small holes around the edge of the petrol filler needing to be aligned correctly for the blowback issue. One of the holes had to be at 12.00 o/c top dead centre.
I am not certain what they did to correct the drunken gauge and it is not perfect but it is at least a LOT better. Before it would not go up past 60% and waved around on bends and under braking. After it would go reliably to 95% and down to around 20% before I failed the chicken test. It would not take more than 60% of capacity to refill. I suspect it was a new sender but with my terrible memory it could have been something else. Andy from AR at Morgan sorted it.
The gauge issue is quite possibly down to the sender's location in the tank and the tank shape.
As for filling - I have tried seemingly every possible location of the holes and had no luck in improving the fill rate. The flip side is that I am patient enough to actually fill the tank.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
Yes, I use this system - the internal metal flap's hinge needs to be at 6 o'clock. But it's still a slog to fill. I've often wondered if using a funnel might help. Or having another filler cap - so having two filler caps. If you opened both when filling one, whether that might make it easier. An expensive solution.
+8 4.8
Ray Offline
Yes, I use this system - the internal metal flap's hinge needs to be at 6 o'clock. But it's still a slog to fill. I've often wondered if using a funnel might help. Or having another filler cap - so having two filler caps. If you opened both when filling one, whether that m ight make it easier. An expensive solution.
. The two filler system on the old +8 worked well. Open both and I could fill at at any rate.
Page 3 of 3 1 2 3
