9 members (jbk, Joske Vermeule, mph, +8Rich, Mogdavid, Sir Percival, Alan Patterson, Steve +8, Deejay),
258
48
Posts837,957
Posts: 2,119 Likes: 70
Posts: 2,119 Likes: 70 |
My washertube under the dasboard is broken again after 4 years. I remeber that a siliconetube was used last time. Now it seems to have again a puncture (I have water on the screen and under the dashboard  Does somebody know the dimensions of the tube i need? So I can search for a bette quality tube? Thank you in advance!
Posts: 76 |
Standard screen washer tube available from Halfords or on line. 3.0 mm id. Probably nylon.
Posts: 1,521 Likes: 61
Posts: 1,521 Likes: 61 |
Neoprene is the tube to go for - Virtually everlasting and obtainable at aeromodellers shops, described as fuel tube it is approx 1/8 in diameter. The original black rubber tubing fitted to my 4/4 2008 sometimes described as liquorice elsewhere on this forum is simply not fit for purpose, it perishes very quickly.
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
Does somebody know the dimensions of the tube i need? For the tee piece to the jets use this. For the bottle to the tee piece use this. It should be available from Amazon Germany.
Ken
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Try the softer more flexible silicon tubing. It was on my car already and shows no signs of deterioration. You may be able to get anti bacterial versions too. I bought some for machines in work to help with bacterial problems in cellulose paste pumping systems.
Thank you for all the appricate advices!  Bernd
Posts: 27,831 Likes: 757
Posts: 27,831 Likes: 757 |
Check also the T piece. On mine it had cracked. I tie wrap the tubes on.
It is done! Both small (black, soft) tubes to the jets where splittet at the tee piece. As suggested I had a look at the tee piece -it was OK. I used some fueltubes with lining outside. I used a tube with 3mm diameter. This tube is suitable for E10 fuel so I hope it will last longer! Thank you again to all for your help!
