10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 251 guests, and 52 robots.
+8Rich 91
Luddite 50
Posts837,969
britmog #542207 11/11/18 03:53 PM
So are you less baffled yet?
kirkusblog.com
1952 Ford 8N
britmog #542271 11/11/18 07:18 PM
britmog Offline OP
Kirk,
Still baffled as my question hasn't been answered, guess I will just work it out myself!!
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
britmog #542365 12/11/18 01:35 PM
Originally Posted By britmog
Kirk,
Hi Bruce,
As you suggested above, you need to split the exhaust at the clamp in front of the side mounts and then you can get at the front baffle with a hole cutter.
Good luck!
Red Leader drive
Chris99 #542378 12/11/18 03:17 PM
Kirk,
Hi Bruce,
Good luck!
Correct & use some exhaust jointing paste on refitting to get a good seal & aid any future removal
britmog #542417 12/11/18 07:36 PM
britmog Offline OP
Gentlemen, thank you.
Bruce
2013 M3W (Olga)
britmog #542430 12/11/18 08:41 PM
...and if you don't already have a supply of holesaws/pilot bits and arbors you could consider getting one of these bad boys... they rip through stainless steel in fine style. The price per cutter looks high till you destroy a few conventional holesaws and any reserves of patience you may have! smile
britmog Offline OP
That is a bad boy.
Bruce
2013 M3W (Olga)
britmog #542561 13/11/18 06:44 PM
kankeL #542790 14/11/18 07:23 PM
britmog Offline OP
Thank you, most helpful have ordered the parts.
Bruce
2013 M3W (Olga)
britmog #542888 15/11/18 01:23 PM
Also, use a hammer drill. Not a standard drill. Otherwise you cant get the bit started
kirkusblog.com
1952 Ford 8N
