2 members (Plus Four Guy, Hamwich), 144 guests, and 15 robots.
+8Rich 102
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
Peter1062
DaveW Offline OP
I've been thinking about doing this splash-guard thing for a while.
The over-rider brackets have four pre-drilled holes in exactly the right place to add a vertical aluminium plate, to partially blank off the engine bay.
Here, two of the holes are visible to the left of the damper where the black dust shield and yellow body meet.
So starting with a cardboard template, using three of those holes, and rummaging through my stock of aluminium sheet, I went for 1.5mm thickness...................
I added edging, which finishes it off.......
And this is the result..................
Other side..............
Next the Exhaust manifold heat shield. I'd already applied 'Reflect-A-Cool' to the trunking. I made up a simple cardboard template which would just slot straight in......this is 2mm thickness.
Covered the back with 'Reflect-A-Cool'....
It fits using the two bolts I also use for my engine cover..........
Continued..........>>>>>>>>
DaveW Offline OP
I also added a small piece to the air filter housing.........
And that's it. Minimal cost and a good session in the garage..... thumbs
Meticulous work as usual.
You should write a book !!!
You coming to Ledgerwoods Dave to sit with the Bad Boys?
DaveW Offline OP
Tempting Kev, although I doubt MrsW will want to.
Is it 1st December?
Ist Dec 10.00am till 3.00 pm
DaveW Offline OP
Noted.
Dave,
What do you use for nibbling your aluminium.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
DaveW Offline OP
Three sets of shears. I can't remember the brand but they are excellent.
One straight and the the other two for curves.
I'll check later but could be Stsnley.
Excellent. I have been advocating keeping the inlet temps down on the gdi this way for some years. Now, since you are handy with ally and tin snips the next thing to do is make a valance for the front. It,s very easy and quite satisfying to get it right. Better still junk the horrible restrictive standard cat and fit a free flow four-branch manifold and a 200 cell cat outside the engine bay. Finally a very wise move with any gdi engine is to run the pcv breather to a catch tank and then atmosphere - or just to atmosphere if you,re not too fastidious. Inlet valve fouling is now too well documented to ignore.
Have you had the GDI through the MOT emissions tests with a 200 cell cat and no PCV?
Bob
2009 Black Roadster
