0 members (), 184 guests, and 25 robots.
+8Rich 102
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
Page 2 of 4 1 2 3 4
Ray Offline
A word of warning where the steering column exit's from the inside, that box around it was chafing through the wiring harness. Something to keep an eye on. Nothing to do with your work Dave, that's great as always. On my 07 4/4.
Originally Posted By KEVFITZ
Excellent Dave
You'll soon have nothing to do !!!!!
If I send my exhaust to you will you polish it please? !!
Outside and inside?
Dave,
I notice your track rod end comes in to the steering arm from below whereas my 4/4 comes in from above. I.e. your tapered pin points up to the nut, mine points down. Do you know why they vary. Something to do with bump steer I think but what specifically?
Also the splitter I use is useless. What do you use?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
DaveW Offline OP
Bob. My splitter is nothing special. Its unbranded from the 1980s. Just a simple cast U shape with a single bolt.
The track rods changed in 2005. The revised set up levels the trackrods and eliminates bump steer.
It can be done on some earlier cars. The stub axle arms need reverse tapering.
I know Mulfab offer this service but they seem to suggest that they move the track rod from bottom to top to reduce bump steer. See below from their Website.
"Bump Steer Correction
We offer a machining service to minimise the bump steer inherent in the Sliding pillar front suspension on Morgans
At some point in the early 2000's the Morgan Factory swapped the track rod end from above to below the steering arm.
We remachine the stub axle to allow fitment of the track rod end back on top of the steering arm.
This then minimises the excess toe out that can occur under hard cornering, making the front of the car feel very nervous.
We will need your stub axles to carry out this modification"
I'm confused because mine is already on top so have Mulfab got it the wrong way round?
Is it best on top or below to minimise bump and roll steer?
Bob
2009 Black Roadster
DaveW Offline OP
Ah well I believe that the stub axles were also changed.
They were in 05/06 because the first owner of my Roadster had the stubs changed.
There may have been earlier changes.
Look how horizontal your track rods are in static position and take a view.
You don’t want to have the track rods level to reduce bump steer
They should be as close as possible to perpendicular to the king pin
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Track rod about 5 degree. King Pin Inclination about 2 degree so 3 degree even before any bump.
I think below the steering arm would be better.
Bob
2009 Black Roadster
Simon @ SiFab.co.uk
I thought it was level with the ground. But as Simon states "Perpendicular to the king pin makes more sense. As My track rods are sloping slightly up with the rod end on top - maybe a problem. I drilled the cone out and use Rod Ends with a SAE thread bolt, sourced from Pegasus Racing, so they can be attached either on top or on the bottom of the stub axle. I will switch them back to the bottom and see if this solves My bump steer.
Button
Simon @ SiFab.co.uk
Slightly up is correct
Remember the kingpin is inclined at about 5-6 degrees
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Page 2 of 4 1 2 3 4
