6 members (BobtheTrain, mickyb, tommog, TBM, Davetherave, Socalm3w), 241 guests, and 33 robots.
+8Rich 96
John V6 50
Topics49,901
Posts838,045
Page 4 of 4 1 2 3 4
Originally Posted By Button
Don't You mean "Slightly Down" to compensate for Caster which is about 2 degrees
I mean lower in the middle where they bolt to the rack, and higher at the outboard ends
2 degrees is too much CAMBER for a road car (assuming its negative) it will hunt every little wiggle and camber change in the road
Try about 0.5 degrees (negative) it will make a world of difference to the steering
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
2 degrees is an awful lot of camber on a road car. I'm guessing that's the king pin inclination.
I'll check some angles more accurately when I get my new inclinometer.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Simon @ SiFab.co.uk
Hmmm. I really do not know what the camber is in My +8 Bitsa. It is a 1998 chassis and crosshead. I guess I must go to an Alignment Shop and find out because something is wrong for sure.
Button
Originally Posted By DaveW
Thanks Jon........you know what you must do next now!!!!!!!
Now chance, I've got a complex leather job waiting on the bench first
Originally Posted By Calypso Red
Hi DaveW, a couple of questions regarding removing/replacing the front hubs on your job. If you are taking off the front hubs to make another job easier (such as replacing the bushes), rather than for replacing the bearings, do you have to replace the rear grease seal? I have a book on Car Care published in 1994 [same year as my +8, so it's cutting edge!] which I find generally very useful. In addition to replacing the rear seal it also advises packing the hub cavity as well as the bearings with grease on reassembling. Do you do this when you have the hubs off, or do you just put back anything which happens to drop out and bolt the wheels back on? Lastly, on your photos of installing Mulfab Steering Bearings I notice the carpet is spotless. Do you use Shake & Vac? Regards,
I never replace the rear grease seal unless I'm changing the wheel bearings, and to be honest I haven't changed a front wheel bearing since...well, probably 2000.
I do always add grease to the cavity, and around the outer bearing.
My carpet isn't quite as spotless as it looks. I cover it when I'm jobbing, and vac it regularly. I do keep thinking about hiring a carpet cleaner to do the whole thing!!!!
Thanks for that Dave, it sounds a bit more straightforward.
1994 +8, BMW Calypso Red.
How do you open the boot?
Dave
No mention of how to replace the hub nut. Do you have to pre-load and then back off to finger tight or is there a torque setting?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
DaveW Offline OP
The way I've always done this is to nip it up gently then back it off to the first split pin position. (Note...for taper bearings!!).
It's something you get a feel for. The balance between tight and no play in the wheel. I put the wheel back on without the brake caliper and spin it to check for both.
It's important to get both bearings seated properly, and to get the slotted washer properly located on the stub.
When set, the nut is just beyond finger tight, although I have had them looser than this in the past on other cars.
If the choice is between tight or slight play, I would live with slight play at the wheel. It all depends on the available split pin positions.
Thanks Dave. That all makes a lot of sense
Doug
1958 Triton 650
That's the way I do it too. One tip I got from Kevin Vernon is to use long nose pliers like these to do up the castellated nut, that way you don't put too much torque on to it. Once it's just snug, you then back off until you get the first line up between hole and castellation. As Dave says, better a smidgeon too slack than too tight.
Page 4 of 4 1 2 3 4
