1 members (ScottMellor), 85 guests, and 142 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,290
Smed., Spanner Juggler
#544161 22/11/18 01:20 PM
SALMO Offline OP
Hi Everyone,
Sunday weather was glorious so went for a drive around the lanes north of Tamworth.
But after twenty years of Morgan ownership it's crunch time.....either the rattles go or the car goes.
So, notwithstanding existing anti rattle strips around the bonnet and rubbers around the doors I have set to work on what will be a never ending task, rattle eradication.
To start with windscreen. On my car it folds on pivots and everything seems to need "stiffening", especially to stop the connecting block for the electric element squeaking on the leather dash roll, squeak, squeak, squeak.
Then we have the hood, a hybrid lift a dot at the screen but a fixed hoop at the rear. The two catches at the rear are useless. No matter if they are adjusted for a tight or loose fit they release within a mile of driving, hood up or down...rattle, rattle, rattle.
Then we have the MMC rack with the tubes fitted near the overriders, rattle, retold, rattle
I will let you know what happens but any suggestions for other places to look will be appreciated.
Regards for now
Geof
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Geof,
What about a mega stereo!!! innocent
Reg
Geof, a couple of suggestions
Rub a bit of liquid leather conditioner on the windscreen heater block & wires
For the hood catches, I use a PTFE based dry lube sprayed down each hole, as it sounds like the sliding catch is not properly engaging with the 'prong', with the rear of the hood out of the way look down the holes as you pull the release lever and check to see the sliders are working, with the spare wheel out you can access the mechanisms
Good look
SALMO Offline OP
Reg, damn, I forgot about that.
Jon, will certainly give the conditioner a try.
Re the catches, they are working ok and are greased up. However, I will strip grease as best as possible and try your PTFE lube (and re-adjust release cable at same time if necessary).
Thanks for imput.
Regards
Geof
Regards
Geof
Originally Posted By SALMO
Hi Everyone,
Regards for now
Geof
If you can hear rattles then the exhaust is too quiet.
20 years is a long time to own a Morgan , no wonder it rattles a bit !
I take My Hearing Aids out.
Button
SALMO Offline OP
B*gg*r, I had new aids only last week!!
But how clever are MMC. My car was built in 2006 and represents a 1995 model. Not only have they got all the design characteristics of that year but all the rattles as well.
Regards
Geof
Regards
Geof
I've heard genuine English rattles are getting too expensive & they are now often bought off fleabay from an offshore source and delivered in a damp bag
No doubt aggravating but it’s a 12 year old car and 2 out of the 3 are aftermarket modifications or fitments, is that really MMCs fault?
