Posts837,997
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Stewart....the rust you have is quite nasty. The lamps are noted for leaking rainwater in and many fill up. The neoprene seal under the lens can deteriorate. Also, the rear that sticks back through the wing is in a VERY expose location with water from the tyres being thrown over it. Solution many do is drill a small drain hole in the bottom of the lens, use silicon sealant under the wing. I sprayed Dinitrol sealer over mine. Replacement bulb holders are not that expensive either.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Stewart....the rust you have is quite nasty. Oi that’s Gingerist!
I love ginger....  But on a plate.
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
I love ginger....  But on a plate. Roger and out.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
I love ginger....  But on a plate. And home made ginger beer made from a real ginger beer "plant". https://www.freshlyfermented.co.uk/product/organic-ginger-beer-plant/
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Kings Ginger is the only Ginger worth contemplating. https://www.bbr.com/producer-1824-the-king-s-ginger
