5 members (Black Adder, MATTMOG, RedThree, Morganmike, stumog), 217 guests, and 27 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,037
Duffs Offline OP
Hi Malcolm, according to RPI the running characteristics are common to Hot wire engines as well, ideally i would like to contact an owner with the same engine whom can confirm the problems and then state that the upgrades work???
I could be looking at a trip to Norfolk when i get chance.
Duffs
Morgan-tastic!!!!
Time Merchant
Time Merchant
Duffs, for the record I have experienced none of the problems you mentioned. Mine is a 4.0 from 2004 and pulls very smoothly, as you would expect, in almost any gear at any speed.
2004 Plus 8
Duffs #52403 05/11/10 04:11 PM
Hi I have a 1999 +8 3.9 with a John Eales mod. I had running problems when I first bought it and had a new stepper motor fitted which cost £130. It was running pretty rough up till then. HOWEVER I then found out on a TVR site that they can be cleaned. I have done mine myself since as it seemed to need it, probably through lack of use. Cleaning costs nothing so give it a go. thumbs
Duffs,
I am not an expert on +8s but my +4 needed a new ECU this year due to intermittent faults.
GoMog has a lot of data on your system. Good luck
http://www.gomog.com/allmorgan/GEMS/GEMSbyPoole.pdf
Originally Posted By John +4
Duffs,
Hi All,
This doesn't apply to the Duff's car. Only for 4.0L with GEMS system.
BR
Daniel.
Duffs Offline OP
Hi Wrinklies, could you PM me some more info on this John Earles mod please???
Thanks Duffs
Morgan-tastic!!!!
Duffs #52815 16/11/10 09:48 AM
Hi
I think the main issue with your car is brain, the land-rover standard ECU sets the fuel mixture every 1000rpm , by adding the chip it will be corrected every 100RPM this does away the steps in acceleration, The RPI chip is ok but I believe John McDonald retails one which is set up specifically for +8's ( light car ) wereas the RPI one is a general chip , If you are not looking at performance this is the only mod I would make .
Cheers
Alan
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
Duffs Offline OP
I was speaking to a a very knowledgeable guy who races an Aero 8 and he has recommended taking my Plus 8 down to a company called Austec near Gatwick whom will rolling road and perform diagnostics as he believes my problems may not be ECU related.
I 'll keep you all updated,
Duffs
Morgan-tastic!!!!
Duffs #55086 15/01/11 03:50 PM
Paul at Austec is a good guy but be prepared for £1000 to rolling road the car. You might want a chat with him first to see if he can offer some diagnosis without setting it up on the rollers.
Duffs Offline OP
Is that £1,000 or £100? shocked2
I hope its the latter.
Morgan-tastic!!!!
