Topics49,911
Posts838,146
Posts: 939 Likes: 21
Posts: 939 Likes: 21 |
Has anyone removed their front and rear bumpers and replaced with just overiders as per later models. If so what’s involved,parts and cost?
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Very expensive mod. Front needs different brackets. I did this with Mr Bumble from no bumpers and although I don't remember how much it was a lot.
Find somebody who wants the reverse and you're laughing!
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 412 Likes: 10
Posts: 412 Likes: 10 |
It will be pretty expensive! I fitted front overiders to my 2009 4/4, they were very easy to fit but cost well over £900 if I remeber correctly. The steering arm goes through the brackets on both side so you need to split the ball joints on the track rod ends. The rear maybe slightly cheaper though?
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1977 Triumph Stag
Craig Jezz
Thanks all for your replies. Certainly food for thought.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I’m Interested why you want overriders instead of a bumper
My first Morgan had front and rear full stainless bumpers, while my latest Mog has the overriders
I can’t do anything on the rear because of the 4 seater design but I would much prefer a full bumper on the front
Because....... Over-riders look way better.......so there.
Posts: 37,486 Likes: 993
Posts: 37,486 Likes: 993 |
Sounds like you two guys could be managing a nice swap with the front end anyway..
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Has anyone removed their front and rear bumpers and replaced with just overiders as per later models. If so what’s involved,parts and cost? Image below shows difference between full bumper (25) and overrider (10) mounts although they attach to similar point on front chassis frame.  I may also be interested in a swap as want to fit valance but retain overriders, and the simpler bumper mount tubes better accomodate such.
