2 members (sprinty, TBM),
279
38
Posts837,992
Posts: 159 |
You are quite right. I added the rubber to seal the gap between the bevelled top of the MMC screen and the clamp, but the problem is the ball joint. A very short stiff rod through the top of the screen stanchion might do the job.
Posts: 1,947 |
CBM you might have trouble come MOT time. The one you used does not have shrouded glass & would be another hazard in a crash. I have a suction mount mirror on my Sunbeam. They may have a shrouded one to suit you. https://www.vintagecarparts.co.uk/products/ca1135-suction-mirror-small. Tim
Posts: 159 |
Thank you Tim - I was not aware of that. If I am still alive in three years' time I will remove it.
Posts: 365 |
Thinking of swapping out my mirrors. Any special instructions/tools to remove them? The bolts look they are in a pretty tricky place to get to.
2017 M3W Sport Green
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Take the velcro trim out and it can be done. You will need a couple of 8mm penny washers as load spreaders. Although the view is considerably less blurred, as the arm is shorter, the view behind is not perfect and you may require a central rear view mirror for full rearward vision. At least you can see most of what is happening behind you with these mirrors.
Posts: 365 |
Thanks a bunch. I took off one of the mirrors but very tight fit. Hard to get the plastic washer, washer and a nut in there and hold them in place while trying to fit the mirror stem through.
Posts: 365 |
The new mirrors are in and fit the look of the car much better. Like others on here went with the Lucas style mirrors.
Posts: 215 Likes: 6
Posts: 215 Likes: 6 |
Omnico 941ST S.Steel Interior Classic Car Mirror with Self-adhesive Attachment
Has anyone tried this? I am hesitant to drill into my MOG.
2018 S&S 110th Beetleback 1934 MX4 Beetleback (in restoration) 1965 Corvette Coupe 327/350
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Has anyone tried this? I am hesitant to drill into my MOG. Question is whether the adhesive will hold a heavyish mirror against the vibration and air currents ... if you are attaching it to a windscreen I'd be dubious. I had an experimental light plastic mirror fly off. Modern adhesives are good but the mirror mount is challenging!
Posts: 99 Likes: 1
Posts: 99 Likes: 1 |
These are readily available from Moss Motors in the U.S. so assume they have in the UK. Have them on my 58 +4.
TomS
