5 members (How, B&C Morgan, bmgermany, jbk, nick w), 281 guests, and 38 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
#554848 19/01/19 09:37 PM
Hi,
I have a 1995 4/4 with an 1800 Zetec engine. I am planning to replace the old cast iron exhaust manifold with a stainless steel unit. However I have been advised that removing the lambda sensor can be a problem and there is a high probability it will be damaged in the process. Can anyone advise me what the lambda sensor type is to let me get a replacement.
Many thanks.
David
On my black top 1.8 Zetec the sensor was a NGK OZA519D1
There was no problem in removing the original
Mike Smith
2007 +4
Thanks for the quick reply. My engine is a silver top. I am not sure how standardised items such as lambda sensors are. You might think that for similar engines Ford would use the same sensor but of course a lot of circumstances might have caused a change.
David
I have found a decent socket made for the job can assist where a spanner won't work when removing lambda sensors on other cars.
A 7pc set of lambda removing sockets cost under £20 on ebay and may be worth investing in.
Ford's can be fussy with regard to the lambda sensor, in a Ford fitting none oem can give troubles, then you end up fitting the more expensive one anyway. How that relates to Morgan using Ford engines I don't know, but just be aware. Found this out when my wife's old StreetKa lost its sensor.
Mark - No Longer driving
David
When I changed my manifold I also changed the ECU for future tuning and replaced the Lambda sensor with a new one from Omex.
The old OEM sensor came out OK but if you do damage yours, you can have my old one. It was working perfectly when I removed it.
Give me a shout if you need it.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
A bit late but many thanks for all the very useful advice. A new Grandchild and other things got in the way of work on the Morgan in the last year but I am back on it now. Thanks again for all the help.
David
David
