8 members (sewin, JMcL, Burgundymog, IcePack, BLUE+4, +8Rich, John V6, TheRabbit), 269 guests, and 31 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,100
#55504 30/01/11 06:36 PM
Barry B Offline OP
Hi All, hope somebody can help!
I have a 1987 4/4 with a 1600cvh engine, when i get to 50mph the front end shakes quite hard. Past 65 the shaking stops. It starts to shake again when slowing down between the same speeds. I'm no professional mechanic just a very enthusiastic amateur. Not sure where to start to look for the most likely source of this problem - I have checked wheel balance and it seems fine.
Any ideas?
Barry B #55508 30/01/11 08:53 PM
South Wales Correspondent
Any ideas?
If you have wires fitted, and especially if you have sticky weights, have any of them come off. If there is the slightest lack of 'true' in the wheel, this is very common. As a related point, if they ARE wires, are they still true or do they need tuning?
Also, check that your tyre supplier/fitter has fitted the right size weigts for the rim
GLLHG
GLLHG #55529 31/01/11 02:36 PM
Complimentary to what G advises, check the steering damper blades (those flat spring steel blades mounted from the stub axle to the side member of the chassis). They should have no radial movement and slide inwards and outwards only. To adjust losen the two nuts which clamp the blade to the chassis. The nuts lock shims in place which you can adjust.
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Bodger #55534 31/01/11 05:05 PM
You have what is known as Malvern dance.
Rather than one specific thing it may be a combination of smaller issues.
You say the wheels have been balanced, also get the tracking checked.
Damper blades as suggested by Frank are the next choice.
Then check the wear on the King pins
Brian
Brian V #55535 31/01/11 05:23 PM
Vibration associated with a specific road speed will be tire/wheel balance.
'65 +4 four seater
The Phantod #55537 31/01/11 05:48 PM
Could also be a flat spotted tyre from heavy braking/standing stationary for long period,
Morgan 4/4 Sport Competition
sprinty #55548 31/01/11 09:56 PM
Try swopping wheels front to back - see what happens.
(in addition to everything else....)
DaveW #55561 01/02/11 07:01 AM
And if all those fail, check the chassis for cracks and that the gusset plates just ahead of the bulkead are not being pushed away from the chassis by rust.
Been there with my '76.
Cheers,
The Phantod #55578 01/02/11 02:13 PM
...except on a Morgan where it may be oscillation of the coil springs (hence the damper blade connected to a brass/bronze plate below the main spring)
1967 4/4 1500 Comp.
Bodger #55579 01/02/11 02:16 PM
Graham, do you know when the gusset plates were introduced? My '67 didn't have them.
Frank
1967 4/4 1500 Comp.
