Posts837,967
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
Can anyone tell me if it’s possible to remove the engine and leave the gearbox in. Looks like I will have the support eh gearbox as it appears the engine is supporting it. I have stripped all the anciliary stuff off, including radiator removal. Looks like it’s should just split and lift.... any tips from someone who’s done it
Cheers
Dave
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Dave, many years ago my CVH engine in a 4/4 stayed in (but pulled forward) as we had to get the 'box out, so should be possible
Good luck 'cos it's a lot of work and skinned knuckles
Posts: 245 Likes: 5
Cheers I was really interested to know if there is enough room to move the engine forwards off the gearbox input shaft - I guess I might now find out until it’s spilt. If there isn’t enough room to clear the shaft then it will have to come out as one - which looks a much bigger job!
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
It is possible to get a CVH engine out without the gearbox, but you do have to remove the cowl and take out the radiator. Here's mine:
Posts: 245 Likes: 5
That’s PERFECT thank you sooo much! Taking off the cowel and rad is easy - well compared to trying to do it when the engine is half hanging off a hoist!! Hopefully it will be straightforward after that. I actually live near Gloucester too!
Cheers
Dave
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
It is possible to get a CVH engine out without the gearbox, but you do have to remove the cowl and take out the radiator. Here's mine: Was that photograph taken near Market Drayton by any chance?
Bob
Might have been
