Posts837,983
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
If you are happy with the position of the existing badges, might it be worth either measuring or marking their position in some way? I only suggest this as getting the position right is very tricky.....
+8 4.8
Posts: 425 |
Thanks for the advice about the heat gun Dave and Britmog. If I can sneak out the hair-dryer without being noticed then I will use that. If not I may have a bash at sticking on a hand warmer pad with masking tape. Excellent point Neilda I will carefully mark their position before removing.
John 2015 Plus 4 (GDI) Sport Green
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Gentle heat and floss. Then carefull cleaning of residue. I was in Berrybrook a few days ago and one Aero there had these badges. Itgot me thinking as I would need to replace the England badge with a dragon....
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Use masking tape on all sides to mark the position.
I'm lucky that because MrsW was a hairdresser, I've had a supply of redundant hair dryers. I currently have two in the garage.
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
I'm lucky that because MrsW was a hairdresser, I've had a supply of redundant hair dryers. I currently have two in the garage. I'm thinking of selling my MX5.
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
I peel/pull the glued stuff careful away an then remove so good as possible with my thumbnail.
Seeking a point of break the glue, than you can pull it off complete.
If it is too hatd to do I use lighter gasoline.
Good luck.
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I use liquid lighter fuel as well for lots of cleaning and especially on glue residue It works brilliantly and nicer than using white spirit
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I use liquid lighter fuel as well for lots of cleaning and especially on glue residue It works brilliantly and nicer than using white spirit .
... don't work and smoke... ;-)
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
.. a supply of redundant hair dryers. I currently have two in the garage. I'm thinking of selling my MX5.  Very good Bob!
