1 members (BHV), 265 guests, and 43 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
If you are happy with the position of the existing badges, might it be worth either measuring or marking their position in some way? I only suggest this as getting the position right is very tricky.....
+8 4.8
Thanks for the advice about the heat gun Dave and Britmog. If I can sneak out the hair-dryer without being noticed then I will use that. If not I may have a bash at sticking on a hand warmer pad with masking tape.
Excellent point Neilda I will carefully mark their position before removing.
2015 Plus 4 (GDI) Sport Green
Gentle heat and floss. Then carefull cleaning of residue.
I was in Berrybrook a few days ago and one Aero there had these badges. Itgot me thinking as I would need to replace the England badge with a dragon.... thumbs
Use masking tape on all sides to mark the position.
I'm lucky that because MrsW was a hairdresser, I've had a supply of redundant hair dryers. I currently have two in the garage.
I'm thinking of selling my MX5.
Best Regards
Lang may yer lum reek
X
X
I peel/pull the glued stuff careful away an then remove so good as possible with my thumbnail.
Seeking a point of break the glue, than you can pull it off complete.
If it is too hatd to do I use lighter gasoline.
Good luck.
René
2018 plus4 (sports green)
I use liquid lighter fuel as well for lots of cleaning and especially on glue residue
It works brilliantly and nicer than using white spirit
Ray Offline
. exting
X
X
... don't work and smoke... ;-)
.. a supply of redundant hair dryers. I currently have two in the garage.
rofl
Very good Bob!
