4 members (bmgermany, Taffmog, nick w, GrumpyPa), 358 guests, and 54 robots.
+8Rich 93
John V6 49
Posts837,990
If you are happy with the position of the existing badges, might it be worth either measuring or marking their position in some way? I only suggest this as getting the position right is very tricky.....
+8 4.8
Thanks for the advice about the heat gun Dave and Britmog. If I can sneak out the hair-dryer without being noticed then I will use that. If not I may have a bash at sticking on a hand warmer pad with masking tape.
Excellent point Neilda I will carefully mark their position before removing.
2015 Plus 4 (GDI) Sport Green
Gentle heat and floss. Then carefull cleaning of residue.
I was in Berrybrook a few days ago and one Aero there had these badges. Itgot me thinking as I would need to replace the England badge with a dragon.... thumbs
Use masking tape on all sides to mark the position.
I'm lucky that because MrsW was a hairdresser, I've had a supply of redundant hair dryers. I currently have two in the garage.
I'm thinking of selling my MX5.
Best Regards
Lang may yer lum reek
X
X
I peel/pull the glued stuff careful away an then remove so good as possible with my thumbnail.
Seeking a point of break the glue, than you can pull it off complete.
If it is too hatd to do I use lighter gasoline.
Good luck.
René
2018 plus4 (sports green)
I use liquid lighter fuel as well for lots of cleaning and especially on glue residue
It works brilliantly and nicer than using white spirit
Ray Offline
. exting
X
X
... don't work and smoke... ;-)
.. a supply of redundant hair dryers. I currently have two in the garage.
rofl
Very good Bob!
