2 members (WR142LLJPN, High Hamster), 253 guests, and 42 robots.
+8Rich 96
Luddite 52
Topics49,904
Posts838,075
Page 4 of 4 1 2 3 4
Was at Bromyard Festival of Speed at the weekend and found this in a shop window display:
DaveW Offline OP
Nice!
I think the aero screen base might be from a full size car.
It's a nice bit of casting.
I'm waiting for some paint before proceeding. I'm going to extend the chassis and try a rear bumper.
I was led to believe the aero screen was a genuine car part.
Nick
DaveW Offline OP
Every time I go in the garage I do a bit more to the pedal car!
It's very alluring.......... smirk2
So, after thinking hard about a rear bumper, and contemplating extending the chassis back through the rear panel, I found that the chassis would be too high. So my solution so far is to extend the chassis rails up to the rear panel, then when its all back together, look at a solution from there. I started by making a simple bent piece of aluminium to mirror the front bumper as a starting point.
Next I extended the chassis rails using aluminium, by sleeving and glue-ing into the existing channels. I'll make a transverse brace when I refit the body. Here the extension is from the arrow.
At the front I've added indicators, and the lower metal plate, which I've drilled and added the two fasteners. This looks much better now!
At the rear, I've added rear lights and indicators. These are HGV side marker LED lights, and are a perfect size.
Finally I've refurbished the inside of the body. Next job will be to wire up the lights, and soon after that I should be able to refit the body to the chassis.
Wow Dave looks great...like a smaller version of StewartS real life 4 seater.
Great addition to the garage Dave and no trouble getting down the drive.
Martin (Deano)
Dave,
I am currently putting together ones of these, I bought a body and some parts so will have to make up a chassis, thankfully I have one to copy...
In the above picture it looks like the floor of the fibreglass seat area comes out is it 2 sections in yours as I need to make a new one...
Thanks
Will
Page 4 of 4 1 2 3 4
