As I've got to move the position of my horn to accommodate my Wolf valance when it arrives, I thought I'd upgrade from the standard MMC 'poverty spec' single horn set up to a pair of high/low horns - particularly as MMC seem to go to the trouble of drilling two mounting holes in the cowl tray.
As a result, I've ordered a pair of Fiamm 'snail' horns of similar proportions to the standard horn.
If this question has been done to death before then please accept my apologies but I did do a search - honest
Crawling under the front of the car reveals two unused female spade connectors with the same wiring colours (LGW & PB) as the connectors fitted to the standard horn.
1) If I brave the tarry blackness with which the wiring is coated and carefully undo the insulation tape between the unused connectors and the currently employed ones, will this reveal a sufficient length of wiring to reach a horn which will be mounted further away than the standard one i.e. is there plenty of spare wiring looped up within the insulation tape?
2) If this is the case, am I right in assuming that its simply a case of plug and play? (9 amp draw each horn apparently)
Many thanks for your help. Again.
