0 members (), 367 guests, and 31 robots.
+8Rich 95
John V6 52
Posts838,016
rockabilly john
D-R,
Took your advise and clamped off the rear flex first. That did it, solid pedal first pump! Ran out of time but now I know to concentrate on the rear units. I’m just happy not to be buying a new MC.
Thanks to all, yer great!
Bill
P3034
Hello
My good friend John Merton from Oz sent me this overnight. I hope it helps you as it sounds like a very similar problem.
I had a similar issue years ago with a 4/4 Series 1 which had been converted to hydraulics using the essentially same approach as the early hydraulic systems on the later Morgans.
The problem was that, in this case, one of the slave cylinders at the front had a bleeder screw issue. When you pumped the pedal the system would suck air back in past the worn thread on the bleeder screw. It didn’t help that the slave cylinder was of the type that had a ball bearing under the bleeder screw.
This had been missed by the local Morgan agent and a number of brake specialists, and someone had actually hammered the brake pipe along the front crossmember to the front left flat obviously to try to “isolate” it.
I spent a full day with a friend to no avail trying to bleed this side. I had a thought bubble early next morning (about 2am), and at dawn called my son- in- law over to test my theory. I put some plumbers’ tape around the bleeder screw, loosened it off so that he could pump and then had him hold the pedal down while I tightened the screw. We then repeated the process. Two pumps and the brakes were fixed.
This may or may not help.
Andy G
1999 +8 , Indigo Blue.
Gone to Porsche
Gone to Porsche
I would now be sizing up the shoe ends, common was they were not original size, and there was to much travel for slave pistons to reach the shoe end.
With the shoes adjusted push back the pistons and see how much gap you have, in each case 4x shoes with a 2mm gap each is a lot, we used to cure it by fusing some weld on the shoe end then refiling to shape.
