Morgan Aero 8
4 members (bmgermany, Taffmog, nick w, GrumpyPa), 358 guests, and 54 robots.
+8Rich 93
John V6 49
Posts837,990
#571978 14/04/19 10:26 PM
Hi
Can you please offer some advice. Since getting caught out in the rain & using my lights, which I do rarely, my S1 lights won't turn off (front & back) at all, regardless with what I do with the headlight switch unless I disconnect the battery. I have tried using the cut off switch, leaving off for 5 mins & then back on to see if that resets anything, but no joy.
Any thoughts - I was thinking maybe a faulty light switch - any idea what car they are off?
Thanks in advance for any suggestions
Ian
do the lights turn on by a relay / solenoid and maybe some electronics...sounds like your control board has got wet with the rain....?
Triumph Herald 1969 13/60
Morris 1970
I have given it a week for the electrics to dry out but still no joy. Maybe I'll try a hairdryer on it.
Perhaps I'll also disconnect the switch (if accessible), as if they are still on it would eliminate the switch as a suspect?
Ian, I would suspect as the powertrain is obviously BMW then the ECU's and BCU's (body control units) will be CANBUS and quite complex.
The switch is quite remote from the actual lights circuit and is just used to trigger a signal to the BCU, which in turn then actually does the 'switching'
I would try and seal up as many gaps in your garage as you can access and bung a dehumidifier on for a week or so, hood retracted, bonnet open and top of the fuse box off too
how about something like this Ian -
Silica dessicant bag
- to help draw any moisture out of the circuit?
I use aerosol contact cleaner on dodgy electrics too - but not sure if I would want it near the ECU;maybe if you could isolate the suspect part.....?
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
To best of my knowledge Series 1 is not Canbus. Try giving Brands Hatch Morgans a ring. They know the early Aeros pretty well and may have a suggestion.
Cheers
Philip
1985 Plus 8 four seater
Malone F1000 - track car
All the electronics on the S1 are controlled by the "Bradley" box so I was told.
Having had mine replaced it was a nightmare, as its a custom bit of work by Morgan (why couldn't they use the darn BMW stuff is beyond my comprehension) and is now no longer available.
As of yet I have found no one who has a clue how to repair the old one (for a spare) either, as its so specialised.
Aero 8 GTN #11
Nick,
- one of the guys on TM had some electronic repair work done (albeit on a Trad.) and was impressed with the work/price.
I'm afraid I can't remember the OP's name but I did keep a note of who he used -
Electronic Repairs
How would you feel about contacting him re. the 'Bradley box' ?
If he could repair it, we might be able to get a situation similar to the steering rack where there is always a spare available for exchange...?
You would then go down in the annals of Aero S1 heroes, as the man who saved us from electronic gremlins notworthy
James
Monkey Z125
Thanks for all of the useful advice so far. I'll spend a bit of time on this over Easter and report back on progress. I hope it's not a defective control box - if so, might have to consider a work around if possible, but will first pay Techniques a visit if my basic common sense efforts fail to resolve the issue
Nick,
Electronic Repairs
James
Hi James,
Not a bad idea - I will have to get in contact and see what they say..
Nick
Aero 8 GTN #11
