0 members (), 240 guests, and 76 robots.
+8Rich 79
Luddite 50
Posts837,931
Yesterday was two weeks to go before we set off in our 1934 MX4 SuperSports for Bruges ( Albert Ball do) then on to Monthery for the Vintage Revival track event.
Over the last couple of weeks I have had the Mogs three speed gearbox out and fitted a new set of Close Ratio Gears, a nice piece of kit.
The old gears whined like a b****** in first and second and were well worn. The noise made an M3W Bevel Box whine seem quite tame !
All went well and the rebuilt gearbox/forks etc went in well.
Those who know are aware that the engine has to come off the front so the propshaft central knuckle joint can be engaged, it is impossible to do without doing this.
So whilst the engine is off it was prudent to check all the gubbins that sit behind the radiator. Like oil/fuel pipes and wiring etc which is difficult to check when all together.
I had drained the oil from the oil tank which is in a compartment, integral with the petrol tank but split by a tin soldered compartment.
At lunchtime on Thursday I was getting ready to begin putting the engine back on when I smelt a strong smell of petrol. My heart sank immediately, fearing the worst, because it usually is with a Mog.
Inside the oil tank was a gallon of petrol which had seeped through the partition due to breakdown of the partition joint.
Many owners have failed to spot this problem and of course the big end gives up quite quickly when the oil is diluted with petrol.
This is not a new problem, owners of Vintage mogs have seen this time and time again. This actually happened to me 10 years ago and I got the partition resoldered that time.
A good look around in the tank with a camera and there was considerable rust around the partition area, would a resolder do the trick again ?
Over a cup of tea I rang a few contacts and amazingly came across a chap in the Midlands who, after listening to my story and where we wanted to be in a couple of weeks agreed to make a complete new tank in 2mm Aluminium. All I had to do was get the old tank to him for 08-00 hrs next Tuesday 23 rd April and the tank would be ready for collection Friday that week. Giving me a few days to fit it, put the dash back then Radiator and Engine lastly. Quite a bit of work actually. It seems that we are on course to make Montlhery after all, or are we ???
Ian. pictures to follow.
Ian
Morgan Family 1929 ( KTW 1100cc )
Morgan S/S 1934
Morgan F4
M3W 2012
Morgan +4 T 1991
at least happened in the shed!!! Good luck with the new tank's cheers
A bit close to the wire but I hope you manage to get it all back together OK in time to explore the upper reaches of the Montlhery banking! drive
Andy
Sounds like you are sorted Ian, but when I was having trouble getting mine made, I found out too late that Ewan Cameron had some on the shelf in Aluminium they just needed the necks fitting in the appropriate positions.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
good luck in it happening when it did and not on the road
Rodger
2004 Plus 8 (wife's)
...and excellent that your aluminium fabricator is able to help you out in such a timely fashion. I hope to see you and your Mog at Monthléry !!
Giles. Mogless in Paris.
Sorry to hear this Ian.
This is something you could really do without right now but I hope you get it sorted in time.
At least it'll give you somethng to do innocent
Seriously, good that you found it when you did and I hope the plan all comes together in time for Albert & Montlhéry.
Red Leader drive
See you soon friends
Dreiradschubser
Dreiradschubser
Hope to meet you in Montlhery
Achim
