2 members (Morganmike, SailingTom2), 266 guests, and 27 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
Originally Posted By cerealsurfer
Seconded on the swap to Hydraulic - Retroford do a kit for T5 box and also Type9/Rocket box.
They may be able to supply a kit for you:
http://www.retro-ford.co.uk/shop/content/type-9-rocket-hydraulic-clutch-release-bearing-kit-bc002
This looks like it would do the trick and looks like what I used on My T-9. I also did a T-5 for My +8 Bitsa. Don't get fooled that this is easy. You will be working in a tight area and the DDE (Deadly Domino Effect)(as Lorne Goldman calls it) is very much in play.
However I have thousands of miles on these installations with no clutch problems other than loosing My clutch on a back road to no where in California. Turns out I topped up the reservoir with hydraulic fluid and kept going. Not sure why this happened yet. Lucky I had a can of fluid in the +8.
Button
I put one into one of my 2.0 Zetec E conversion 4/4’s with a Competition twin plate 7” clutch on a custom lightweight flywheel. It was mated to a Quaife Heavy Duty straight cut, close ratio, Ali cased Type9.
