2 members (Rovert, Bitsobrits), 334 guests, and 44 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,996
RedThree
The benefit of ACF50 is its ability to penetrate the tiniest gaps so ideally suited for the wing to body areas - and just spray it anywhere that moisture might lie or two pieces of metal meet. Good on wire wheels too and doesn't harm rubber or plastic. I'm sure there are other similar products out there but I've settled on ACF50 and give the car a good treatment once or twice a year.
1968 4/4 1600
1950 Auster J5B
Kitfox S5 Outback
Jodel D9
1988 Peugeot 205 GTI 1.9
I find it a lot easier to pour a small amount of ACF 50 into a container and use a small artist brush to apply it along the seams, although 3 in 1 works fine too.
Also put some behind the door fittings, mirror base, door handle, side screen knobs etc as I've seen quite a few older Morgan's with corrosion around these points.
The sample pots of ACF50 that occasionally come in goody bags are an ideal tool for application of a small dribble in all the important little places.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
+1. They work really well.
2025 MG ZS EV aka Trigger
I thought it was just me ooo
Simon
2002 4/4
2021 Audi A1 sport
+2
Reg
I removed my front wings in order inspect the joint area, i was amazed at the method of fixing to the body however at 5 years old it was in good shape and i re-attached them using a waxoyl based underseal in the joint area. Whilst i was at it i removed those stupid tread rubbers, fortunatly, before they'd damaged the paint and caused any corrosion.
I think the rear wings will get the same treatment next winter.
E
E
What's the problem with tread rubbers please? How would they damage the paint?
Tom
2018 Plus 4
Some have found that the nuts and bolts that secure them to the running boards start to corrode beneath the rubber. First clue that it is happening is when you see little pregnant bumps appearing along the rubber. As advocated by Dave W, it is better to secure them with a non metallic/plastic fixing. If you ignore it, there is the risk that the corrosion will spread into the paintwork itself and start creeping out under the strips.
Although I haven’t experienced these issues in 8 years of Morgan ownership, if I had my time over, I would not specify tread rubbers. They are a nuisance for trapping water when cleaning the car and another trap for polish residue along the edges.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
