7 members (PaulJ, sewin, jbk, uvk33n, JohnHarris, Chris Cosher, TBM),
280
33
Topics49,913
Posts838,166
Posts: 902 |
One thing that 'surprised' me when I removed the dash was, it was veneered plywood, not solid wood...
Great job but veneer is not a problem or poor quality. Solid wood is not often used even for high quality furniture or in this case dashboards as plywood is a better and much more stable core material which doesn't warp or shrink. The general exceptions are solid pine and far eastern 'mahogany' furniture which can be of variable quality!
Rob
Posts: 122 |
Great job. Did you position using trial and error or did you manage to get some measurements to make a template? Oh - and what size hole saw did you use?
2017 4/4 80th Anniversary
Posts: 465 |
Great job but veneer is not a problem or poor quality. Solid wood is not often used even for high quality furniture or in this case dashboards as plywood is a better and much more stable core material which doesn't warp or shrink. The general exceptions are solid pine and far eastern 'mahogany' furniture which can be of variable quality! Interesting! Thanks.
Dark Red 4/4 80th Anniversary
Posts: 26 Likes: 1
Posts: 26 Likes: 1 |
I used a 60mm Bosch hole saw, with suitable arbour. I dropped the dash to check there was nothing behind it in the area that I was going to cut the hole and then put the dash back so it was firm and secure whilst I drilled it. I dropped the steering wheel to its lowest position so I had straight line access with the drill whilst cutting the hole. Unfortunately I could not find a car with a clock to template the position so just guesstimated it from pictures. I made a 60mm paper cut out as a mock up to check I was happy before making the cut. Due to the thickness of the dashboard the 'legs' of the mounting bracket were too long for the locking nuts to engage the threads so I had to shorten them by 7-8mm using a Dremel. Other than that it was quite straight forward.
Posts: 122 |
