2 members (Black Adder, Luddite), 210 guests, and 26 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,037
Duck Oil Service Spray.
I use it when it starts squeaking.
Mark - No Longer driving
Rog Offline
Originally Posted By Lowflyer
What does the panel think?
Just a thought thinking
Lubricating between the leaves can effectively make the spring less stiffness by reducing the sliding friction. Whilst the softer springs may make for a nicer ride and possibly improve the car’s traction on a choppy surface there may be another consideration. If the car is one of those where the suspension has a tendency to bottom or make contact with the body then reducing the frictional damping action may exasperate the situation.
Roger
If you want a proper job, the spring needs to come apart and each leaf can then be filed/lapped smooth.
You can also buy modern stick on interleaving. In tbe good old days, interleaving was the norm and resembled a thin nylon strip. Now they don't bother.
On the car its a huge pain to get the lube where it matters anyway, and you stand a better chance using a screwdriver to spread the leaves slightly.
When I replaced the springs on Bumble, I slackened off the throughbolt and left them overnight twice (each side) with chain lube sprayed into the gaps. Then I wrapped them in Denso Tape.
Rog Offline
Just for fun I lubricated the rear springs with something a little different this time.
This cheapo stuff from Scewfix is really thin.
I lifted the car on the frame to open the springs as best I could and shot it in between the leaves. The clear pressurized lube easily blasts straight through the spring and out the other side. For the first few seconds the excess ran out deep red, presumably flushing out iron oxide dust. These 2 year old springs have only done 3.5k and were kept lubricated so an eye opener to see what washed out.
Still weeping after the first run out and the black spring stained red.
I noticed something else too. For a while now I have not been able to slip my original 32mm setting block between the assists and top spring surfaces without forcing it, both gaps had closed by a few mm. However after the run the block slipped in again with ease so something had an effect on the static height. Was it just the benefit of the lubrication? Or could the accumulation of this red debris ‘clog up’ the spring, gradually zapping its strength over time if not removed?
Something I will be watching with interest but for now the old cart springs feel really tip-top and the car a delight to drive.
Roger
TBM Offline
I've previously used Chain Grease, however on recommendation I've swapped to Wurth HSW100. Seems to be pretty similar.
I'm finding the new 5 Link squeaks and creaks just as bad as dry leaf springs anyway, I suspect its the numerous bushes in the various link arms
That does surprise me Jon. Mine is so quiet I can hear all the other creaks and groans from the body/sidescreens/tools moving etc.
Andy G
1999 +8 , Indigo Blue.
I think that post was a long time ago, all's settled down now with some o ring safe lube and alternative SSL coilovers to sort the overly stiff factory version
IIRC you have the more compliant full SSL conversion Andy thumbs
