0 members (),
315
43
Topics49,897
Posts838,017
Posts: 327 |
What does the panel think? I have recently lubricated the leaf spring and spring hanger bushes with AC50 followed up with few brush loads of EP90.i'm sure the ride is smoother, What experience do you have on frequency of lubrication of these bits of kit. My pals 20hp 1924 Rolls (ex Mr Bird of Birds Custard Powder) has leather fitted covers over its springs c/w grease nipples which might infer regular attention was needed.
Posts: 37,480 Likes: 989
Posts: 37,480 Likes: 989 |
I do mine annually with white aerosol grease and it quietens them down, some people have been known to lubricate them then wrap them in Denso tape. Quite a few use motor bike chain grease as long as you use something it will be fine they are only cart springs after all  .
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
I'm sure DaveW and others will be along to advise but I've had several cars with leaf springs and have always used motorcycle chain lube spray, it's not very sticky.
Oil and some spray lubes can cause road grit and muck to stick causing wear between the leaves. Wrapping is a good idea to prevent this and holds the grease in.
Not sure if AC50 is good for rubber bushes long term?
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
An annual spray of Motor Cycle chain oil works for me on my 2011 4/4
Posts: 321 |
JCK 1960 Plus 4 Roadster
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
I’ve used Waxoyl for years. Cheap, works well and has good creeping properties..
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Motorcycle chain oil for me. Take the spare wheel off to get at the rear.
Posts: 3,727 |
Annual Spray with Motorcycle Spray Chain Grease - Tool Tray out for ease of access.
I would worry less about leaf spring wear when I see Grit Covered Bump Springs open to the elements (viz. DaveW's Gaiters)
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
I work in a bikeshop (no motorbikes) and don't like the chainspray.
For both bicycles and motorbikes the spray is a little bit glueing that it doesn't "fly away". This means that it it also glues dirt.
I prefer for both bikes and the MOG a light oil as using in household or a cheap engine oil.
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 8,698 Likes: 498
Posts: 8,698 Likes: 498 |
I used to use motorbike chain lube (as listed 'safe for o-ring chains') then you know its safe to blast all the rubber bushes too which tend to creak
I'm finding the new 5 Link squeaks and creaks just as bad as dry leaf springs anyway, I suspect its the numerous bushes in the various link arms
