10 members (Hamwich, Willowgreen320, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike),
254
47
Posts837,969
Posts: 987 |
Suggestions please for a good chrome wire wheel cleaner/polish that will remove light rust. Many thanks
Posts: 27,833 Likes: 758
Posts: 27,833 Likes: 758 |
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
For initial cleaning, a thinned down application of Swarfega (?), hose it off then use autosol metal polish. Upon completion wrap in cling film and go every where by bus !!!
Posts: 987 |
Thanks chaps, I’ll give this a go after I return from LM
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
Is there a gap in the market for secondary double glazing for wire wheels ? Get a plastic/plexiglass round disc made up to go behind and in front of the wheel, could save hours of fettling.
love the idea please make me a set.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I had chrome plated wire wheels on my last Mog with a tiny bit of rust showing on a couple of areas
I used a fine grade steel wool with Autosol and it worked a treat
I was told early in my Mog ownership this advice by Andy at Lifes Motors:
Fine wire wool for getting tarnish off chrome plating Sponge scouring pad for badly marked stainless steel
Never ever mix the two
I then used Blackfire Wet Diamond metal sealant to give the whole wheel a clean using cloths (It smells just like a thinner version of autosol but goes a long way and is much easier to wipe on and buff up)
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Is there a gap in the market for secondary double glazing for wire wheels ? Get a plastic/plexiglass round disc made up to go behind and in front of the wheel, could save hours of fettling. Already done. Well for the spare wheel...…. It would affect brake cooling on the front.       I chose the red one and sold the black one on...…….
