1 members (sezznowt), 405 guests, and 53 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
Georgetoad, woolfie
Page 9 of 15 1 2 7 8 9 10 11 14 15
Rog Offline
Originally Posted By Heinz
Roger, thanks for your detailed answers. It should not ne too difficult when I cut some cardboard to reduce the efficiency of the aluminium radiator, which consequently to your thoughts should help to lower the water temperature of the engine.
I have understood the consequences and effects but I haven't really fully understood how it works and how the connection between the warm bypass water and the cooler radiator water come together.
I assume that both water hoses meet before the thermostat. But how is the mix determined, and why does too little cold water seem to come into the circuit towards the engine behind the stat when the new radiator cools so well, better than the old smaller plastic radiator? But the engine runs hotter...
Your cardboard experiment will be interesting.
I don’t know the detail of the Sigma so can only attempt an explanation on the Duratec.
Below is a pic of the Duratec showing the coolant paths and how they mix at the stat housing. Also a pic of my old 90deg stat. Note the stat is a double valve arrangement. The primary valve is pretty standard. The secondary valve is the plunger at the end that seals against a seat in the block. When the primary valve opens to let the rad coolant into the block the secondary valve closes off the hot by-pass coolant.
As said before it looks like it is dependent on a precarious temperature balance between the hot and cooled coolants that might hold the answer. Just a wacky theory…… smile
Roger
FWIW the coolant bypass whether it's integrated into the block or an external pipe, is always a narrower bore than main rad cooling circuit.
This is the case with conventional cylinder head or rad return thermostat location.
When I replaced broken radiator with a Mulfab alluminium one, I noticed a drop in the cooling water temperature. This must be because the Mulfab one being made from alluminium and being larger. As I did not like the esthetics of the new radiator sticking out from below the front, I got a stubby valance from Wolff Engineering, to cover it up as well as to get some extra protection. Result is that the running temperature is slightly up again.
In order to lower the under bonnet temperature, I installed bonnet extenders from John Taylor. This also provides some extra free volume around the itg air filter, which should help breathing. An additional bennefit is the increased sound level from the air intake.
I wonder if closing the gap at the bottom between radiator and front of engine (as mentioned earlier in this discussion) would be of additional help to help both air intake temperature and flow (given the bonnet extenders).
Cheers,
Bert
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
It's not a difficult job Bert, because you can start with a flat sheet of aluminium, and improvise. I've done it on each of mine. Of course it's impossible to really evaluate the outcome, but none of mine have run hot, even last summer.
I had a good run today and I'd say the new deflector plate made no difference whatsoever. Still gives an indicated 96 once fully warmed up at 40 to 50 and got up to 102 at 70 on a long gentle hill, just about 100 at 70. The fan didn't come on as far as I could tell. I will leave the plate there to see what happens in the summer.
It seems like the thermostat is controlling the inlet temperature to the engine and the dashboard water temperature gauge is reporting the outlet i.e. 88 deg inlet constant but the more the load the higher the outlet temperature.
crazy2
Simon
2002 4/4
2021 Audi A1 sport
sid Offline
Originally Posted By CooperMan
On the 3.7 Roadsters the only intake for air is via a hole cut onto the base of the Mustang airbox / filter housing here..
It's not very large in area and draws intake air from close to the back of the engine and the footwell bulkhead, and is only about 6 inches from the hot exhaust manifold
The filter sits flat in the top of the airbox & there's plenty of space below...
So I've cut some additional intake holes below the filter line to allow more air routes in, and hopefully some will be cooler air pushed in by the forward facing bonnet louvres, and I'm lining the 'box' with reflective foil tape
Next task is an air scoop to the back of the bonnet side louvres or a Naca duct
Inspired by Jon's much earlier posts relating to getting more cooler air into the 3.7 Roadster's air box, I've also cut a 4" hole in the box but then used a ducting elbow that came from Screwfix to help draw cool air from the side vents in the bonnet.
A quick spray of matt black and I think it looks quite tidy.
I've left the original hole in the base of the box open, but I'm hoping that this - very cheap! - addition may improve things.
Only a proper dyno test will confirm one way or the other whether there's any difference in performance, as I must say I can't notice any, but I just feel that anything's got to be better than the standard arrangement.
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue
Ex Indigo Blue '99 +4
Ex MogMMX Innovations winner
Sid, looks a good idea
My MK2 version now has a scoop fitted above the rad which feeds air via a duct direct into the front airbox hole
The engine deffo runs cooler as the fan cuts in a lot less
Sid, photos of Mk2 upgrade
Intake scoop mounted on top of rad
Neat job Jon. I feel if I was to do the same I would need to start with an unbutchered airbox as that is what the MMC mod is IMO.
Do you happen to know the source of (intact) airbox?
My investigations revealed there were two 3.7 V6 Mustang airbox variants, and the OE slab filter (replaced with K&N) on mine matches the 2011-2014 one with straight not angled outlet. Even then it would have had a hole at the front to accept the rectangular cold air inlet pipe (see my photo further up this thread) which would be sited just behind left hand bank on Morgan, so maybe yet another Ford airbox variant.
sid Offline
Nice idea, Jon. Interesting to hear that the car now runs cooler, too.
Maybe your design restricts some of the airflow that would normally have by-passed the radiator, but is now forcing more air to go through it?
Anyway, you've now prompted me to experiment with installing a blanking plate above the rad, as the cooling fan certainly kicks in a lot more than it ever did on my old +4.
So thanks for that, as it's given me more excuses to disappear into the garage for some more tinkering...!
Sid
