8 members (IcePack, SwissMogFan, Graham, G4FUJ, Simon, Julian BB, +8Rich, RichardV6, John V6), 352 guests, and 27 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
Page 2 of 7 1 2 3 4 5 6 7
Looks like the it's either the MMC comfort kit fitted to the steering arms without the top brackets or it's a one off/home made similar arrangement. If it's the latter and turns out to cause any problem then it could be swapped for the full MMC arrangement. It doesn't have the Empire kit wishbones.
The air filter looks to be standard, just with the Sopwith Pup "In the event of the propeller or engine being removed the gun MUST be retimed" brass plaque.
Not having the Centa wouldn't be a showstopper but you might want to budget for getting it done if it hasn't already been converted.
Good luck!
Q
Q
Check with the GCC laws, i believe if it’s over four years old you won’t be able to register it
osten Offline OP
Thanks for the feedback Gentlemen.
I've taken into account your concerns and wish list of upgrades but in turn I have a few questions regarding the existing listed upgrades.
A. Crankshaft nut upgraded to S&S new style non reversible type - what is that ?
B. Rear hub upgraded to new style to provide more belt clearance between belt and tire - None of you mentioned it - Why did he do that ?
C.Removable engine cooling fan, Switch on dash. Fan avoids “skip beat” in hot weather - Isn't that the Urban cooling kit ?
Next - questions related to above posts:
1. Centa - where do I source it and for how much ? Would the dealer over there be able to source it and upgrade ?
2. Exhaust modification - Is that really a vital upgrade or really a modification for performance ? I'd rather do this at a later stage once i'm into the car rather than go mental early on. Thoughts ?
3. Cooling kit - refer to Point C
4. Comfort kit Empire - Again does it need fixing if it ain't broken ?
5. I've driven them in both position - can't say I even noticed
6. UAE doesn't have any age limit on car imports - There's tons of US imports driving around here without any issues.
7. Can you turn the mileage back to km ?
Piloting Saint Ex the Morgan
In reply to some of your questions:
A. Crankshaft nut upgrade (and cambelt idlers?) means that the crankshaft bolt shouldn't smash its way out of the cam chest cover, a good thing.
B. Rear hub should be an anodised black one that gives better belt clearance, a good thing.
C. This sounds like it has a less efficient home made cooling kit rather than the MMC one with it's ECU re-map. Maybe better looking. Not ideal for a very warm climate.
1. Centa is only available from MMC and is a big job, engine out. Don't know current price.
2. Exhaust mods not essential but will help with better and cooler running.
3. Very good to have Urban Cooling Kit, for a hot climate particularly. If it doesn't have the MMC cooling kit and ECU map it will go into skip fire mode if hot.
4. The track arm riser adaptors look like the ones used with the original Empire Kit, not the MMC type. It does not have the Empire steering correction kit fitted, just the steering arm ends. There were some issues with these if not fitted correctly, safer to have the MMC version fitted.
I don't know about the final 3 items. Hope this helps with your decision.
Item 5 relates to the gear change. The earlier rear position sometimes gets a bit difficult for access with a passenger. Less of a space issue with the further forward change position but it is a case of what you prefer. They can be changed.
A: The original design had a tendency to fail, leading to the bolt coming out through the cover and the pulley to come off the crank, sometimes damaging the crank too. The updated version uses a conventional hex head bolt rather than a Torx Plus bolt plus a different pulley and Loctite. If it has been done, it's done, don't worry about it.
B: The original hub and sprocket combination put the belt very close to the tyre and it would often rub on the tyre sidewall. Also, basically MMC engineered the car so that there was a step between the front and rear sprockets rather than them being properly in line so they left the outside face flange of the sprocket off leaving the last 6mm or so of the belt running off the edge of the sprocket. This tended to give uneven wear on the already fast wearing original aluminium back sprocket. The later hub moved the sprocket away from the tyre, a bit closer to being in line with the front one and allowed it to retain the outer flange although it does tend to make the belt run against the outer flange and squeak when dry. There was also a change from aluminium to a steel rear sprocket which tended to go with the hub change. The aluminium ones wear quickly, sometimes incredibly quickly, while the steel version seems to just keep going, as it should. Steel one is a seriously heavy bit of kit but is the preferred option, pretty much fit and forget.
C: The urban cooling kit has a large cowl and fan, ties into the ECU and works automatically. I'll take a guess that what is on this car is a pair of smaller less visually intrusive fans adapted from one of the kits for big Harleys and works off a manual switch. Advantages of the factory cooling kit is that when at speed its ducting does a good job of directing the cooling air around the engine giving better, more even cooling (this wasn't by design, but more by happy accident!) and it just turns itself on when required. But it is quite big and obvious. Some people (including me) don't have any cooling fans and have never had the engine go into the over heating skip fire mode, but I live in north east Scotland, not the Emirates! Hot weather and traffic jams are kind of strangers to me. If the fans seem to work then "not broken, don't fix it" seems appropriate.
1: Not cheap, think it's in the £1000 range just for the parts and the engine has to come out to do it so it's a lot of work just to get to the point of being able to fit it. Sourced from MMC, any dealer should be able to get and fit it. If it hasn't been done, expect to get it done sooner or later. Maybe even negotiate to get it done (and the clutch checked while the engine is out) before the car leaves California.
2: Not essential to upgrade but the standard pipes do lead to a lot of heat being retained in the heads as they are so restrictively baffled and you are in a somewhat warm climate. Drilling out one or more of the baffle plates has worked for quite a few people which gives a much cheaper route to getting the heat out of the heads and reducing detonation. Drilled baffles and a bit of trimming of the restrictive stock air filter cover will get a lot of the benefit of Stage 1 tuning without the expense.
4: Agreed. Looks to be a "home made" comfort kit on the steering. This is not meant as an insult! Someone in California actually came up with a design very similar to what the factory subsequently did with the comfort kit and it could be from that source. The main difference, visually at least, was that while they both used similar tapered risers on top of the steering arms to raise the track rods up to something like parallel to the top wishbones, the factory kit also has a reinforcing bracket from the top of the suspension upright to the top of the riser while the Californian version didn't.
5: Later, forward, gear lever position gives a bit more elbow room and fewer bruised ribs for passengers. Can't see it as a deal breaker either way.
6: No idea.
7: See answer 6!
Have fun making the decision.
Andy
Compensator kit (Centa) invoice June 2017 GBP695.52 plus tax.
MMC have a random number generator to come up with prices. The output of this machine varies depending on how loudly you shout at it.
Centa Drive Parts, Feb 2015, £995+tax
Urban fan kit, Feb 2015, £125+tax
Rear hub (black), Sept 2015, £333+tax (+£25 for the crappy Chinese bearings)
Andy
Online NoMood
Strange that the additional reversing (backup) light is operated by a dash switch when the MX5 gearbox has a reverse light switch already connected to loom with cabling to rear confused2
