2 members (bmgermany, Moggo),
311
49
Topics49,897
Posts838,017
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
HalfFull, Is the belt centered or is it partially off of the flange? how much?
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 257 Likes: 3
Posts: 257 Likes: 3 |
HalfFull, Is the belt centered or is it partially off of the flange? how much? About 1 mm off the edge
Aka Joejoe
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
It’s absolutely fine to run without the outer flange on the rear sprocket.
The best I can manage is to have the belt just about on the sprocket while going forwards. However, in reverse it starts to work it’s way off the edge.
If you lose the flange on the bevel box sprocket the belt will try and eat it’s way though the rear shock absorber, just like mine did last year. That was due to the bevel box rear mounting plate welds cracking and pulling away from the frame tube (Non NVH mounting).
Posts: 423 Likes: 2
The way the sprocket is mounted, if the belt runs to the inside, the inner flange will not stop the belt from rubbing on the tire. With the black pulley, will a spacer work to move it out?
Posts: 45 |
If you lose the flange on the bevel box sprocket the belt will try and eat it’s way though the rear shock absorber, just like mine did last year. That was due to the bevel box rear mounting plate welds cracking and pulling away from the frame tube (Non NVH mounting). Identical experience here... same visual when rolling forward or reverse. Spoke to my dealer and he said it’s normal and no cause for concern. If it means not spending money on more upgrades - I’ll take it!
Norwalk, CT, USA
'12 Morgan 3 Wheeler #401 '79 Porsche 911SC '73 Norton 750 Commando
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Never had problem with mine february 2013 And now more than 30000 miles.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Mine has always run about an 1/8" of an inch off the outside of the pulley with no detriment.
Posts: 423 Likes: 2
Is it up against the outside pulley on the bevel box as well?
Almost but not quite.<a href="https://www.tm-img.com/image/KYj2M"><img src="https://www.tm-img.com/images/2018/03/08/IMG_4475.jpg" alt="IMG_4475.jpg" border="0" /></a>
I wish I could work out how to add photos
