5 members (bmgermany, potty45, John V6, GrumpyPa, How), 261 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
HalfFull, Is the belt centered or is it partially off of the flange? how much?
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
About 1 mm off the edge
Aka Joejoe
WW11 MOG
WW11 MOG
It’s absolutely fine to run without the outer flange on the rear sprocket.
The best I can manage is to have the belt just about on the sprocket while going forwards. However, in reverse it starts to work it’s way off the edge.
If you lose the flange on the bevel box sprocket the belt will try and eat it’s way though the rear shock absorber, just like mine did last year. That was due to the bevel box rear mounting plate welds cracking and pulling away from the frame tube (Non NVH mounting).
The way the sprocket is mounted, if the belt runs to the inside, the inner flange will not stop the belt from rubbing on the tire.
With the black pulley, will a spacer work to move it out?
Lance
1981 Plus 8
2016 Three Wheeler
Identical experience here... same visual when rolling forward or reverse. Spoke to my dealer and he said it’s normal and no cause for concern. If it means not spending money on more upgrades - I’ll take it!
Norwalk, CT, USA
'12 Morgan 3 Wheeler #401
'79 Porsche 911SC
'73 Norton 750 Commando
Never had problem with mine february 2013 And now more than 30000 miles.
Mine has always run about an 1/8" of an inch off the outside of the pulley with no detriment.
Is it up against the outside pulley on the bevel box as well?
Lance
1981 Plus 8
2016 Three Wheeler
Almost but not quite.<a href="https://www.tm-img.com/image/KYj2M"><img src="https://www.tm-img.com/images/2018/03/08/IMG_4475.jpg" alt="IMG_4475.jpg" border="0" /></a>
I wish I could work out how to add photos
