7 members (Paulxj, +8Rich, Alan Patterson, DCH, TalkMorgan, Tresco, Craig Jezz), 214 guests, and 41 robots.
+8Rich 82
Luddite 50
Posts837,942
After rear tire removal to replace the sprocket, I needed to bleed the drum brake. I took an old glass cider jug and soldered a couple of 6mm (1/4 inch) pieces of copper tubing into the steel screw-on cap, one long, one short. The long one is connected via plastic tubing to the bleed connection; the short one is connected via plastic tubing to a vacuum source (air-powered venturi). Without ever pumping the brake pedal, I drew fluid out of the rear brake bleeder while watching and refilling the reservoir with DOT 4. One man job, and the brake pedal feels firmer now than it did before.
John, retired Marine Engineer
87 Morgan +8+, 12 Morgan 3W
Good job👍
Top tip👍🏼
