Topics49,915
Posts838,218
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Great find Cooperman
Top Mog replacement bits that look like they might actually work
Although I don’t think my wipers are terrible and do seem to do mostly what’s expected, there is definitely room for improvement
Posts: 3,565 Likes: 14
Posts: 3,565 Likes: 14 |
[quote=CooperMan]Chaps, as you requested here's the update... Great result! I wonder what you are going to buy for the money you saved... Isn't that a typical lady's train of thought vis a vis sale prices and other 'savings'? Hold on, am I being too gender specific here? There must be a man who thinks the same way, ah yes, Bert............
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
[quote=CooperMan]Chaps, as you requested here's the update... Great result! I wonder what you are going to buy for the money you saved... Isn't that a typical lady's train of thought vis a vis sale prices and other 'savings'? Hold on, am I being too gender specific here? There must be a man who thinks the same way, ah yes, Bert............  Well...as I'm shoving the classic Mini up Shelsley Walsh in a couple of weeks, I'm spending some £££ on prep for that, at 52 yrs old it needs some TLC
Posts: 5,587 |
Vital thread for any mogster who wants to bin Moggy rubbish and replace with 21stC stuff , thank you Cooperman for this , need to get these asap as despite having more wipers than any other normal car they don't actually clear the screen of wet very well !
Posts: 314 Likes: 3
Posts: 314 Likes: 3 |
I did it too  The wiper blades WBS8 fit pretty well I recorded a video in slow motion with the unmodified wiper blades. VideoThe wiper blades have slightly different paths on the way there and back (about 3-5 mm). On the way back they touch the upper edge of the windshield (visible in the video). But only the rubber touches the metal frame. At the very end of the video you can also see that the right wiper, seen from the front, touches the metal frame on the right a bit more. ![[Linked Image]](https://www.tm-img.com/images/2019/08/23/IMG_E3981.jpg) To reduce this I made the same modification as CooperMan. But the result is a stronger touch at the metal frame below. I have now mounted the wiper blades unmodified and will try to shorten the right wiper blade a bit. Then it should fit. The wiping behaviour is significantly better than with the original wiper blades (no rattling at all). I'm curious about the first test in the rain.  From my point of view this is a very recommendable (and not very expensive) modification. Many thanks CooperMan
Michael 2018 Plus 4 Sport
Michael, if you slide the rubbers out you can cut down the overhang of the thin metal slips as your close up shows & them trim the rubber too
Mine were tested in very heavy rain for several hours of continuous driving & worked very well
Hope you're still enjoying the Mog, I took you some build shots at MMC last year, if I remember correctly ?
Posts: 314 Likes: 3
Michael, if you slide the rubbers out you can cut down the overhang of the thin metal slips as your close up shows & them trim the rubber too Jon, this is exactly what I had planned and have done in the meantime. Here is a video of the 4-7 mm shortened wiper blades: VideoHope you're still enjoying the Mog I do that very much! The odometer is just before 20,000 km  I took you some build shots at MMC last year, if I remember correctly ? That's right! I've added them to MMC's photo book and often show them to interested people to explain the construction of the Classical Morgans.
Posts: 5,587 |
Have just bought three of those little wipers from carbuildersolutions , they seem to have dropped the postage charge since I went on there before the Welsh mog trip - wished I'd had them then but only saw the post recently , looking forward to getting them and fitting them and lots of rain !
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
Have just bought three of those little wipers from carbuildersolutions , they seem to have dropped the postage charge since I went on there before the Welsh mog trip - wished I'd had them then but only saw the post recently , looking forward to getting them and fitting them and lots of rain ! they usually do a discount like this for the Bank Holiday weekend only - so order soon...!! James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 14,750 Likes: 158
Posts: 14,750 Likes: 158 |
Michael
For me the videos come up as private. In other words I can't view them.
