7 members (Vansrv6, mph, vbalddave, Laurens, John V6, ChrisConvertible, Supermog),
297
Topics49,915
Posts838,218
Posts: 902 |
I want to change the air filter. What one do I get
I have seen Velociraptor, twin velocity and many others. What model Harley do we buy for?
Posts: 8,705 Likes: 416
Posts: 8,705 Likes: 416 |
As I understand the Velociraptor does not have a fitting kit for X-wedge engine, although the best looking IMO. A component has to be custom made. I believe it's the mounting bracket. ![[Linked Image]](https://i.imgur.com/pSEBL7c.jpg) If you buy an air filter option (there are several) from the S & S catalogue for X-Wedge you know it will fit.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I went with the S&S Stealth Muscle cover after talking with S&S. Fairly easy install, no bending of anything to get it to fit. I did have to bore out the holes in the cover for the two posts to slide in easily; i did it in stages (a few thousandths at a time) so as to not bore out to much material. It comes with a plug to plug an unused hole but the plug they provided was the wrong size so a trip to the hardware store fixed that. ![[Linked Image]](https://www.tm-img.com/images/2019/08/27/IMG_0391.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/08/27/IMG_0392.jpg) It is easy to remove and clean and boy oh boy did it make a difference in how smooth the engine responds to a little gas pedal!
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
it is like Colace to the engine
it is like Colace to the engine Exactly so!
