8 members (Montegue, TalkMorgan, tezzer, Graham, G4FUJ, RichardV6, CooperMan, JohnHarris, Haggispeed),
349
Posts837,983
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
I bought the J. W. Speaker LED's per Blake's recommendation. Very much like yours.
Not one week passes when I was coming home in rural Vermont when a black bear was running across the road I was on and, with the stock incandescent lamps, I would have never even seen him until it was too late! As it was I saw him in time to slow a bit and swerve out of his way with plenty of room. I don't know who was more scared, the bear or me.
You'll have more amps available as well!
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Well, I must say that persistence pays off, as well as the kind reassurance from fellow TMrs. I managed to get the W clips rotated flat onto the small rim of the LED lamp, and it worked with the W clips spread way out to what I would call a lazy W. ![[Linked Image]](https://www.tm-img.com/images/2019/07/24/IMG_5280.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/07/24/IMG_5282.jpg) I can hardly wait for a night time drive👍😎 off topic... but I am honoured to be a part of that squadron
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I am going to have to get up real early or go to bed late at night to try them out before I need them.
And yes, I am now ready for the other lamps I have to be put in place and wired into the circuitry,
Happy Motoring👍
And yes, The Squadron lives on, just no lion here, only a large German Shepherd that would never get into the plane, oops, Three Wheeler😊
I did not Post photos of the clips that gave so much grief, so here they are. ![[Linked Image]](https://www.tm-img.com/images/2019/07/29/W-Clip.jpg) They have to sit on the flat spot on these. ![[Linked Image]](https://www.tm-img.com/images/2019/07/23/IMG_5275.jpg) These W clips need to sit perfectly flat on the replacement lamps otherwise the lamps and bezel will not fit into the bucket. It took a lot of persuasion to get the clips too lay flat on the thicker J.W.Speaker LED lamps!
The lighting project is moving forward along with the oil cooler add. Here is a dry fitting to see if it all lines up; so far all is well. I took a piece of 6061 Aluminum tube and started cutting spaces out of it. ![[Linked Image]](https://www.tm-img.com/images/2019/08/30/IMG_5381.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/08/30/IMG_5382.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/08/30/IMG_5383.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/08/30/IMG_5385.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/08/30/IMG_5388.jpg) Now the car will get raised up so I can get under it to work on the oil lines and the electrical connections. I have a question that is purely a what do you think question; would you paint the aluminum mounting bar Black, Clear Coat, Body Color or Red??? Or??
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
That’s a lot of lights! Certainly a unique look... I wonder whether one would fit in front of the air cleaner for a cyclops look?
Posts: 1,947 |
What do the low orange & yellow lamps do, turn, marker or driving?
The lighting project is moving forward along with the oil cooler add....I have a question that is purely a what do you think question; would you paint the aluminum mounting bar Black, Clear Coat, Body Color or Red??? Or??
Chrome!  With overriders !!!
Paul, not unique, I saw what High Noon, and several others had done with the front lamps. What is unique is how I am mounting them with a custom front plate bracket.
Thanks Rodger, that was the original goal and probably where I will end up.
