6 members (+8Rich, Image, Morganmike, Alan Patterson, gomog, Deejay), 260 guests, and 57 robots.
+8Rich 88
Luddite 50
Posts837,956
Yep, I know about VIN being the legal one and it is easy to find. I even had to make a VIN once for a vehicle I built.
The only number I have not found is the ASH Frame number; where is that located? That probably tells more about the number of 3 Wheelers and where mine is in the scheme of things.
Somehow in the excitement of getting the new machine I lost the Build Number in an email dump. I have the Build Date, but as I found out that is a dream number that has nothing to do with when the car leaves the factory.
MMC marks the ash frame somewhere… but not sure if they make the mark visible unless you dismantle large body parts. Maybe they even mark every frame in a different place (we all know they love doing things at random sometimes LOL!).
www.speedymarmots.com
I have an early 2012 model and the ash frame number is on top of frame at rear under the plastic cover
Fairly hard to see as has been painted over
Ditto on the 2016 model I had and easily seen stamped on wood close to fuel sender.
Thanks guys, I will check the next time I am back there, probably for wiring the backup light and stop lamps.
