5 members (DCH, TigerTim, Haggispeed, Lionel Mandrake, TBM), 320 guests, and 42 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Rev 4K Offline OP
I have followed Dave's plan.
put in a new fuse.
Input 12v - no problem
Switch test with output connected to test bulb - no problem
Re-connected everything and - no problem, brake lights working.
Realised that the reversing light is on the same fuse so checked the bulb . looks alright.
Pt the car in reverse, no engine just ignition on, Blew the fuse.
I will have a look underneath tomorrow at the fitting but where do i find the reversing switch ??
hope its not in the gearbox.
Thanks for continued assistance
2004 Silver Roadster S1
But must the reverse switch be the faulty item or could it be a short on the way to the rear drive bulb?
Paul, as it's far easier to access the light / bulb I'd start there, the bulb holders are a known source of trouble due to corrosion & even the bulb could have blown & shorted internally (worth a quick swop-out)
Happy birthday Jon!
Paul I have known several reverse light switches go short circuit (seem to be mostly on Minis - the originals). They are located above the gearbox usually activated by gearlever position. However, as Jon says, start with the easy bit smile
