1 members (+8Rich),
358
36
Posts837,992
Posts: 13 |
The restoration of my late 1973 (build) Plus 8 is continuing very slowly, but is progressing. I am now dealing with the wiring - every connector is corroded and none of the earths are good. As part of tracing of the wires, I have two lamps on the dash and I do not know what they are for. Could someone with a similar Pus 8 please tell me? Also, though I have an oil pressure switch on the oil pump housing, there does not seem to be a wire in the old harness for it and there is no mention of such a switch or warning lamp on the appropriate GoMoG wiring diagram. Was the switch wired in and back to the dash? If so, what colour is/was the wire?
I prepared an annotated pic of the dash showing the lights in question but I cannot understand the help section on how to attach / post the pic. So words will have to do:
In the speedo, there is at the bottom left a blue high beam warning light, and bottom right the ignition light. Centrally, between the speedo and the instrument cluster is a horizontal row of three lights; on the right is the indicator warning light, but what please are the other two - a larger red central light and a smaller red light on the left.?
Any and all help greatly appreciated.
Francis
Posts: 338 Likes: 7
Posts: 338 Likes: 7 |
If it't the same as mine the large red light is the Hazard flasher and the small red light is the brake warning light for the parking/handbrake.
'34 Family 4 '70 +8 '03 Hummer H2
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Convention has it that the oil presure sender wire to warning light will be yellow/green if this helps.
Posts: 13 |
Thank you Georgetoad and I guess it is the same as yours (yours '70 +8; mine '73 +8) so I can try to trace the wires back from the lights. And this would indicate there is no light for the oil pressure, notwithstanding the presence of a pressure switch on the pump housing. I will however look for a yellow/green wire, as suggested by Richard.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
The handbrake warning light also serves as a brake warning light should one of the brake circuits fail.
Kind regards
Arwyn
Posts: 5,460 Likes: 475
Posts: 5,460 Likes: 475 |
FrancisG you might also find this page useful when wondering around wiring...? http://www.team.net/sol/tech/LucasColours.htmlGood luck.
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Ignore the instructions for uploading photographs to this forum - they either need updating or removing (or the facility reinstating. It was disabled when trying to find the reasons for forum slowdown). Instead, join www.tm-img.com and follow the instructions here: https://www.tm-img.com/page/ifu
