10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 251 guests, and 52 robots.
+8Rich 91
Luddite 50
Posts837,969
Page 6 of 8 1 2 3 4 5 6 7 8
head lights
Good price.
Originally Posted by rockabilly john
head lights
Good price.
But not DOT or E marked so "off road use only".
kirkusblog.com
1952 Ford 8N
The result in the night :
POSITION LIGHT (veilleuses in French) :
LOW LIGHT (feu de croisement in French)
HIGH LIGHT (feu de route ou plein phare in French) :
Lille - France
Plus Four 2024
👍 nice lighting.
The light scatter & lack of defined cut off line on dip is very poor, it will cause dazzle of other drivers coming towards you & in the UK would be an MOT fail
Hi CooperMan,
There is no technical control (MOT) for motorcycles and three wheels in France, which allows a lot of freedom on the MTW ...;)
Lille - France
Plus Four 2024
I agree & nestor you need a bit more adjustment as the 2 light patterns are not at same height.
This is a typical headlight pattern on dip, this Mog is on traditional headlamps & halogen bulbs, the little flick up is aimed at the n/s kerb
For comparison this is a modern BMW with properly developed LED headlights - note the flat cut-off to the light spread
UK drivers should be very careful of some of the aftermarket LED headlamps on offer, many are poor quality / not E marked / poor beam pattern, as best you will fail your next MOT at worst if your vehicle is involved in an accident your lights may be a contributory factor, accident investigators very often remove the indicator & brake light bulbs & subject them to a test
More Light wink
Lille - France
Plus Four 2024
