2 members (sewin, Tony Quinn),
262
53
Posts837,962
Posts: 902 |
Posts: 1,947 |
But not DOT or E marked so "off road use only".
Posts: 2,539 |
Posts: 875 Likes: 157
Posts: 875 Likes: 157 |
The result in the night : POSITION LIGHT (veilleuses in French) : ![[Linked Image]](https://zupimages.net/up/19/40/feng.jpg) ![[Linked Image]](https://zupimages.net/up/19/40/vixa.jpg) LOW LIGHT (feu de croisement in French) ![[Linked Image]](https://zupimages.net/up/19/40/4vu7.jpg) HIGH LIGHT (feu de route ou plein phare in French) : ![[Linked Image]](https://zupimages.net/up/19/40/1q1y.jpg)
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
The light scatter & lack of defined cut off line on dip is very poor, it will cause dazzle of other drivers coming towards you & in the UK would be an MOT fail
Hi CooperMan,
There is no technical control (MOT) for motorcycles and three wheels in France, which allows a lot of freedom on the MTW ...;)
Posts: 1,947 |
The light scatter & lack of defined cut off line on dip is very poor, it will cause dazzle of other drivers coming towards you & in the UK would be an MOT fail I agree & nestor you need a bit more adjustment as the 2 light patterns are not at same height.
This is a typical headlight pattern on dip, this Mog is on traditional headlamps & halogen bulbs, the little flick up is aimed at the n/s kerb ![[Linked Image]](https://www.tm-img.com/images/2019/01/15/Roadster-LED-2.jpg) For comparison this is a modern BMW with properly developed LED headlights - note the flat cut-off to the light spread ![[Linked Image]](https://www.tm-img.com/images/2019/01/18/i3-LED-on-dip.jpg) UK drivers should be very careful of some of the aftermarket LED headlamps on offer, many are poor quality / not E marked / poor beam pattern, as best you will fail your next MOT at worst if your vehicle is involved in an accident your lights may be a contributory factor, accident investigators very often remove the indicator & brake light bulbs & subject them to a test
