0 members (), 292 guests, and 18 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
My 4/4 with 165/80/15 T-Trac2 shows no understeer. Toe in 1mm, Camber negative 1 degrees, one tenth bar less pressure at the front tyres, 1,8 bar at front and 1,9 bar at the rear in warm summer conditions. I have my second set of T-Trac 2 since this spring.
Sounds interesting. I'll see if I can find any.
Probably a bit far away for you, but Paul Harris Tyres, near the Belfry, can certainly supply T Trac 2 smile
And balance the wheel / tyre combo correctly after fitting.
Seems to be positive remarks on the vredestein classics. Unfortunately they now cost an arm & a leg. Has anyone got the vredestein sprint classics fitted ?
& any comments.
(Of interest maybe Avon CR6ZZ after 25500 miles. Tread depths UK 2011 4/4 NSF 3/2/3mm OSF 2/3/4mm NSR 2/3/4mm OSR 4/4/4---- Run at 22psi Front 24psi Rear)
Can you believe this:
“We regret to inform you that this information is currently unavailable on our site. Please check this with Vredestein producer.”
From MyTyres answer to the question please confirm that the vredestein 175/70/15 are tubeless.
