8 members (Vansrv6, Craig Jezz, vbalddave, bmgermany, cerealsurfer, JMcL, sewin, +8Rich),
109
Topics49,905
Posts838,100
Posts: 698 Likes: 7
Toys for Boys Talk Morgan Regular
Posts: 698 Likes: 7 |
For some reason my headlight main beam isn't working. If I pull the stalk back it it flashes but if I push it forward the main beam doesn't engage and the blue main beam indicator doesn't light. All the fuses are fine. Could it be a relay, and if so which one of the four? Anyone got any ideas?
Omne trium perfectum
Posts: 5,470 Likes: 476
Posts: 5,470 Likes: 476 |
I have not even stood close to a modern three wheeler, so anything I type could be rubbish.... IF you have fitted more powerful lamps.. and done quite a bit of night running on main beam, could be that the contacts have burned in the switch..? Not too uncommon on all sorts of modified vehicles....? The main/dip switch for whatever reason seems suspect No 1..?
Posts: 8,700 Likes: 416
Posts: 8,700 Likes: 416 |
For some reason my headlight main beam isn't working. If I pull the stalk back it it flashes but if I push it forward the main beam doesn't engage and the blue main beam indicator doesn't light. All the fuses are fine. Could it be a relay, and if so which one of the four? Anyone got any ideas? There are five relays on an M3W with cooling fan. Two are for headlamps, dip/main and main beam - each have a blue/slate wire for identification, check by substitution with similar diode relay (worth having a spare). Check also stalk switch and TSM/headlamp unit connectors. If no luck with suggestions would suspect the latter.
Posts: 338 Likes: 1
Posts: 338 Likes: 1 |
Hi, Exactly the same problem on a friends Mog was elusive to fix. However it turned out( after a dealer looking for three weeks) to be a part Morgan call the Indicator Module. It is listed in Ian Bretts alternative parts list on MTWC website. Available from dealers to order and a bugger to fit. It has been responsible for many similar problems, I now carry one as a spare ! rgds Ian
Ian Morgan Family 1929 ( KTW 1100cc ) Morgan S/S 1934 Morgan F4 M3W 2012 Morgan +4 T 1991
Posts: 698 Likes: 7
Problem solved! Seems it was an operator error! If you flash the headlights you then need to push forward twice to re-engage main beam functionality. Thanks for the other information though, much appreciated!
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Well, that is certainly good information! Flash the headlamps and you need to reset the system by a double push forward. Thank you👍
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Black Adder: You beat me to it, I found that out after much frustration trying to locate the issue. Was fiddling around with the switch/stalk and must have pushed it forward twice to reset, wonder how many people have replaced relays,etc. (which by disconnecting the power does the same thing) for no need?
Posts: 61 Likes: 1
Posts: 61 Likes: 1 |
Not quite getting that ? My headlights ( main beam ) are on . I can flash my high beams fine ( by pulling stalk back once ). If I push stalk forward twice , to Reset ? My main beam ? My main headlights are on . If I release my stalk from pulling back , my lights simply resort to main beams . Nothing extra happens if I push stalk disarm twice or 100 times. What’s supposed to happen is high beams ie brights are supposed to be Locked on . Which does not happen . My brights /high beams do not come on when stalk pushed forward ? So I’m not getting the whole ReSet concept ? And it flies in face of function , I think . I checked all my fuses 👍🏼 . Isn’t there someone whole has had this specific problem? I would appreciate some knowledge and help . Specific accurate help preferably...lol
