7 members (IcePack, BLUE+4, Ruut Bianchi, Paulxj, JMcL, Burgundymog, Image),
251
Topics49,905
Posts838,100
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
My 4/4 with 165/80/15 T-Trac2 shows no understeer. Toe in 1mm, Camber negative 1 degrees, one tenth bar less pressure at the front tyres, 1,8 bar at front and 1,9 bar at the rear in warm summer conditions. I have my second set of T-Trac 2 since this spring.
Posts: 132 |
Sounds interesting. I'll see if I can find any.
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Probably a bit far away for you, but Paul Harris Tyres, near the Belfry, can certainly supply T Trac 2  And balance the wheel / tyre combo correctly after fitting.
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
Seems to be positive remarks on the vredestein classics. Unfortunately they now cost an arm & a leg. Has anyone got the vredestein sprint classics fitted ? & any comments. (Of interest maybe Avon CR6ZZ after 25500 miles. Tread depths UK 2011 4/4 NSF 3/2/3mm OSF 2/3/4mm NSR 2/3/4mm OSR 4/4/4---- Run at 22psi Front 24psi Rear)
Can you believe this: “We regret to inform you that this information is currently unavailable on our site. Please check this with Vredestein producer.” From MyTyres answer to the question please confirm that the vredestein 175/70/15 are tubeless.
