5 members (MATTMOG, TeddyAds, JMcL, DaveW, TalkMorgan), 322 guests, and 88 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,755
E
E
The 3 wheeler uses a 5 speed MX5 Mk3 box that are not too choosy with gearbox oil.
The six speed MX5 Mk3 boxes like Redline MT90 or Castrol Syntrans Multivehicle. These improve gear changing at low temperatures and are GL4 oils (gear oils) which are not too slippy like GL4/GL5 oils ( Diff oils with EP additives that are too slippy for the gear synchronisers.)
There are no favoutite among the MX5 community with regards to oils for the 5 speed box but I would use a GL4 oil. I have changed gearbox oil in loads of MX5's.
Originally Posted by Dab of oppo
That'l be the gearbox, the bit in the middle.
The bit at the back can be known as: back axle, final drive or Diff. Depending on who you are talking to.
Thank you👍
The bit in the middle, love it.
on old goldwings we simply call the rear drive box as a pumpkin
Rodger
2004 Plus 8 (wife's)
Like banjo housing for the rear end
The gearbox filler is a 14 mm square drive - which I would suggest you get as the bolt fuses to the Au housing and can become slightly stiff!
A tip if you are going to drain either - remove the filler bolt first just incase you have problems getting them off and you have already emptied the box.
