10 members (JohnHarris, Saxonian, TBM, Alan Culpitt, Alan Patterson, PaulV, Davetherave, Scrambledsignals, Black Adder, sewin),
116
Topics49,918
Posts838,261
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
If the electric 3 wheeler is ever resurrected it will eliminate many of the drivetrain issues the ICE sufferers from, although knowing Morgan it will have its own unique set of issues! They would want to replace the S&S with something equally charismatic... say a Tesla coil?
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
Still awaiting a reply from MMC regarding availability of parts or cost and availability of the Centa kit. Might be worth giving Nobby at Krazy Horse a call. He knows his stuff and KH keep a good stock of parts.
Andy
Posts: 132 Likes: 1
Posts: 132 Likes: 1 |
Dab If it was me once I had the Centa kit I would pop over to Phil Bleazey for the mods to enable you to change the rollers from under the car in 30mins I now plan to change mine yearly regardless of condition.
PaulR
Posts: 722 Likes: 24
Posts: 722 Likes: 24 |
Dab If it was me once I had the Centa kit I would pop over to Phil Bleazey for the mods to enable you to change the rollers from under the car in 30mins I now plan to change mine yearly regardless of condition. Paul Do you have the Bleazey kit ?
Posts: 132 Likes: 1
Laurens Yes I do.. a happy customer
PaulR
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
If the electric 3 wheeler is ever resurrected it will eliminate many of the drivetrain issues the ICE sufferers from, although knowing Morgan it will have its own unique set of issues! Maybe wiring issues
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Does Lucas the Prince of Darkness have anything to do with it?
Posts: 1,075 |
This is what the Lovejoy unit looks like. ![[Linked Image]](http://catalog.lovejoy-inc.com/Asset/a1450.jpg) The three outboard holes would bolt into the rotor/hub attached to the crank with the big nut. The inner three bolts would then bolt to the shaft that would be coupled to the flywheel adapter shaft. This allows for a bout a 7.5 degree wind up under max torque of 408#ft. I know, the torque pulses are greater, but I would still think this is a good fit for a trial run on someone's M3W. The BMW does not allow for any wind up and is basically just a "slightly" flexible coupling that will allow for very slight misalignment, but again, no wind up for torque pulse. This going to basically be a direct coupling setup. Oh well, the Centa is the ole "bird in the hand" scenario and probably a good enough one at that, with Phil's pucks.
Dan
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Ah, yet another variation on the two solid parts with an elastomer in between theme.... And in my profession, when one says Lovejoy coupling, we are thinking this: ![[Linked Image]](https://www.tm-img.com/images/2019/10/24/Lovejoy-coupling.jpg) Lovejoy in fact makes many types of vibration resistant, torsional stress reducing and misalignment mitigating couplings.
Steve Late 2012 M3W
Indeed - https://www.lovejoy-inc.com/products/jaw-type-couplings/ is quite interesting. Some of these are limited in RPM, although the material options for the coupling was insightful: wonder when you'd use non-dampening bronze in a coupler? SOX (NBR) Rubber (Standard Insert) – Nitrile Butadiene (Buna N) Rubber is a flexible elastomer material that is oil resistant, resembles natural rubber in resilience and elasticity. Urethane – Greater torque capability than NBR (1.5 times), provides less dampening effect, and operates in a smaller temperature range. Good resistance to oil and chemicals. Not recommended for cyclic or start/stop applications. Hytrel® – Flexible elastomer designed for high torque and high temperature operations. Excellent resistance to oil and chemicals. Not recommended for cyclic or start/stop applications. Bronze – Rigid, porous oil-impregnated metal insert exclusively for low speed (max 250 RPM) applications requiring high torque capabilities. Not affected by extreme temperatures, water, oil, or dirt.
