Topics49,909
Posts838,129
Posts: 5,471 Likes: 476
Posts: 5,471 Likes: 476 |
Grumpy2, sorry to read of your heater woes. My +8 is of 85 vintage thus anything I type could be rubbish in relation to your heater system.
From your description of hot wiring and dimming lights relative to the heater fan motor circuit, that your thinking on the heater motor being seized may be correct... if there is any way you can get at the fan blades then trying to force them to move might just be enough to get it going again... However if you have put a large enough fuse in to the previously blown holder you could have burned out the motor windings, thus even with the mechanical aspect of the fan freed off it will still not run and just blow fuses..
if there is any sort of filtration on the air intake for the heater in the engine bay if you remove that it could improve the airflow through the heater rad while on the move..?
As for the water circulation, it seems likely that it will have a valve to cut of circulation through the heater box though whether it is a stand alone item in the engine bay of part of the heater box it`s self..I do not know. though the heater might just need to be bled due to an air lock in the rad...?
On my old Morgan the heater flaps are spring loaded with knobs on, thus no cable operation.
The heater valve is mounted in the engine bay and operated by cable which when operated either inhibits or allows the flow of water from the engine through the heater box, to determine whether there is flow or not through the heater with the engine running and water warming up, it could be a simple matter to feel both flow and return pipes for the heater to see if both are at similar temperatures, if one is hot and one not then it is possible you have a restriction, either the valve or the heater rad might have crud in it.... .
If your valve is u/s and of the remote mounted type (not part of the heater box) and is creating the problem, then you can remove it and replace it with a bit of copper pipe, which will allow flow but obviously no control over the flow, though at this time of year a permanently hot heater rad may be no issue..?
If the heated rad/core it`s self has an internal restriction then it is just possible to clear that without stripping the heater out... by identifying both flow and return heater pipes in the engine bay, disconnecting both, and connecting a garden hose to one end to flush out the heater rad.... then connect the garden hose to the end of the disconnected heater pipework to reverse flush the rad, if there is crud in the heater rad then you may see the water initially as brown in colour then turning clear, when the flow is reversed it may again run brown then clear, thus repeating the reversal process a few times may improve flow.... on reconnection you may need to bleed the heater by running the engine and disconnecting the return pipework till water flows out of it FROM the heater, connecting it back up while flow is still present, a bit messy but could solve the lack of flow issue if it exists...?
Do remember that if you have been messing about and loosing coolant in the process to then top up antifreeze ..!
Good luck in your fault finding..
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Its IN for OFF - OUT for ON.
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Its IN for OFF - OUT for ON. Not on my 1993 4/4 it isn't John! Wasn't on my '76 or or '97 +4 either  I guess it depends on the water valve as fitted.
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
sorry Graham, i'm with JTL on this one In for oFF etc on my 1989 4/4 Its IN for OFF - OUT for ON. Not on my 1993 4/4 it isn't John! Wasn't on my '76 or or '97 +4 either  I guess it depends on the water valve as fitted.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
sorry Graham, i'm with JTL on this one In for oFF etc on my 1989 4/4 Its IN for OFF - OUT for ON. Not on my 1993 4/4 it isn't John! Wasn't on my '76 or or '97 +4 either  I guess it depends on the water valve as fitted. If the water valve looks like this: ![[Linked Image]](https://www.tm-img.com/images/2019/10/29/PB146453.md.jpg) Then the valve is closed when it's in the position illustrated. As far as I'm aware this valve was pretty standard through out the 1980's and probably later. As can be seen, the valve is closed when the operating wire is pulled, so the under-dash knob is out. To operate the valve, the knob is pushed in, pushing the operating arm and allowing the valve to move away from the bottom and permit water to flow through the valve. So yes, IN is ON and OUT is OFF for me.
Last edited by Hamwich; 29/10/19 12:09 PM. Reason: Got it the wrong way round at first.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
On my 94 +8 IN is OFF and Out is ON, the pull knob operates the water flow to the heater core. The heater core is under the metal plate on top of the bulk head, you can check to see if it runs hot with the engine running. The blower is next to it on the bulk head and should be able to be reached fairy easily. Goes without saying that you need to have the vents open on the side of the heater in the cabin!!!! The instructions can be found in your manual on page 8 under Hand Operated Controls.
Here is a picture of the Heater Instructions from the 94 +8 manual: ![[Linked Image]](https://www.tm-img.com/images/2019/10/29/8HeaterInstructions.md.jpg)
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
Britmog - I don't have that page in my handbook - thanks
Hamwich - that's an old BL type water valve and I've certainly not yet found anything like that on my car.
The heater matrix is warm enough and I suspect the fan is indeed seized. I'm going to have a try to remove it tonight
Gary
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
At some point, MMC must have removed the on / off water valve. My heater matrix is permanently fed with hot water and there is simply a flap to stop the hot air coming into the car.
I'm going to add a valve so I can turn it off in hot weather as a bit of the hot air always finds it's way past the flap even in the off position.
Bob
Posts: 853 |
Its IN for OFF - OUT for ON. Not on my 1993 4/4 it isn't John! Wasn't on my '76 or or '97 +4 either  I guess it depends on the water valve as fitted. Had same confusion on my 1994 Plus 8 the original valve was very stiff to operate and so i bought a replacement and discovered it worked oposite from the original. So obviously MMC had a change of mind as to which way was best
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
