5 members (piquet, GrumpyPa, JMcL, DavidR, vincentvg), 296 guests, and 45 robots.
Luddite 50
Posts837,951
rid967 Offline OP
I found the little Perspex block with which one slides open the side screen window lying on the garage floor today. I have never had any issue with previous Morgan side screen. It has just popped out!
Anyway, I intend gluing it back in with clear super glue but before doing so would appreciate any advice as to whether or not super glue would be appropriate or not.
3.7 Roadster
Porsche 964 C2
JCW Mini Cooper S Cab
BMW F750GS
+4 4 1995-2002 / LM 62 +8 2002-07
PJB Offline
I have used a DIY cheap superglue to stick these back on, worked fine. PJB.
I used super glue.
Superglue works...
Superglue worked for me
Nick
Common problem. Mine fell out only last week. I had some clear 2 pack araldite kicking about and applied it with a cocktail stick successfully.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Use as little as you can get away with
My knee jerk reaction would be to use a plastic solvent adhesive but accept you could make an awful mess if you got it in the wrong place.
rid967 Offline OP
Thanks for all the advice. I like the idea of using a cocktail stick to apply the glue.
Regards
3.7 Roadster
Porsche 964 C2
BMW F750GS
I lost the block before it was glued.☹☹☹. I 'll have to make another one.
Stefan
AR4
